2 hours ago, xqzlls said:
i built a pc an when i turn it on to install windows it says install now then shuts off and reboot or it shows the windows logo then restarts
if you havn't set the physical windows disk at first priority you will have to take out the USB after the first part of the install has completed...  it might just pick up the install drive again...
