HDMI Switch issues
Solved by Wzyss,
1 minute ago, Kirishima_Rei said:I thought about that. However my PS5 has no issues. At least that's what the video output test claims. I had similar issue with my other HDMI 1.4 usb Hub even before I plugged in that switch so that’s why I used this simple converter.
It's definitely got to be something along the line there. You can at least rule out the display or a particular cable being an issue by just going direct to the monitor from your PC. Otherwise it definitely sounds like a trial-by-fire situation.
