Budget: € 3000 EURO
Country: Netherlands
Usage: Gaming (also VR gaming)
Other details:
i currently have a computer that has:
  • CPU: i9-9900k
  • GPU: ASUS ROG Strix GeForce RTX 2070 super OC edition (ASUS)
  • Motherboard: ROG STRIX Z390-F Motherboard
  • RAM: 32GB (4x8) of DDR4 2666mhz (Corsair vengence RGB PRO) running at 2600mhz because 2666mhz was constantly crashing...
  • PSU is a Vengence 500 watt. yes this works somehow
  • case: Carbide Series 275R Mid-Tower Gaming Case — Black
  • Display: 2 Monitors (one 1440p 144hz trough Displayport the other 1080p with HDMI to just have another window up while gaming or doing anything else) VR headset is valve index.
  • Storage: I currently have 2 NVMe drives, 1 sata SSD and 2 HDD's
don't need wifi, using an ethernet cable.
I want to look at upgrading this, I already figured out, I think.. that would almost certainly means a new motherboard and thus new CPU and possibly a new GPU but i have no idea what to look for.
I want to be able to play games at 1440p with at least a stable 60fps, currently most recent games can barely run at 60 fps on the lowest settings with DLSS on performance and even then it constantly drops below to 30 and sometimes even lower than that
now I keep a decent amount of stuff open so that's on me, but even if I close everything but the game I get at most 2-7 more fps, I tried.
I don't need to be able to run everything on ultra but more than low would be nice because combined with DLSS on performance its starting to look quite bad.
I feel like I would need to buy a whole new PC because mostly everything barley fits in my current case
so i am looking for advice on what parts I would need to build an entire computer (except for storage, that I can figure out) and to be able to play games at 1440p and in VR or other advice because I have no clue.
https://linustechtips.com/topic/1546715-help-how-to-upgradebuild-pc/
9 minutes ago, lvdaXD said:
Budget: € 3000 EURO
Other details:
  • CPU: i9-9900k
I would personally do a GPU upgrade. But if you want a full system upgrade for 3000 euros: (also how does that psu work)
I can't justify a 4090 with the 400 euro markup rn, so xtx we go
PCPartPicker Part List
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor  (€369.95 @ Megekko)
Motherboard: MSI B650 GAMING PLUS WIFI ATX AM5 Motherboard  (€182.95 @ Megekko)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (€124.90 @ Amazon Netherlands)
Video Card: ASRock Phantom Gaming OC Radeon RX 7900 XTX 24 GB Video Card  (€982.95 @ Azerty)
Case: Corsair Carbide Series 275R ATX Mid Tower Case
Power Supply: Silverstone DA850 Gold 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (€99.95 @ Azerty)
Total: €1760.70
Generated by PCPartPicker 2023-12-12 19:58 CET+0100
Replacing the system makes the most sense.
A new case with USB-C front panel port.
NVMe pricing is very good at the moment. Consider replacing multiple drives with a single 4TB unit.
An ATX 3.0 compliant PSU for better transient handling.
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor  ($358.14 @ Amazon)
CPU Cooler: Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler  ($33.90 @ Amazon)
Motherboard: MSI MAG B650 TOMAHAWK WIFI ATX AM5 Motherboard  ($217.99 @ Newegg)
Memory: G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($104.99 @ Amazon)
Storage: Samsung 990 Pro 4 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($299.99 @ B&H)
Video Card: MSI GAMING X SLIM GeForce RTX 4070 Ti 12 GB Video Card  ($784.99 @ Newegg)
Case: Lian Li LANCOOL 216 ATX Mid Tower Case  ($96.99 @ Amazon)
Power Supply: Thermaltake Toughpower GF3 TT Premium 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($119.99 @ Amazon)
Total: $2016.98
Generated by PCPartPicker 2023-12-12 14:40 EST-0500
CPU: *AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor  (€369.95 @ Megekko)
CPU Cooler: *Deepcool AK620 68.99 CFM CPU Cooler  (€68.90 @ Amazon Netherlands)
Motherboard: *Asus TUF GAMING B650-PLUS ATX AM5 Motherboard  (€192.00 @ Amazon Netherlands)
Memory: *Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (€124.90 @ Amazon Netherlands)
Storage: *Kingston KC3000 2.048 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (€128.85 @ Megekko)
Video Card: *MSI VENTUS 3X OC GeForce RTX 4080 16 GB Video Card  (€1258.00 @ Paradigit)
Case: *Lian Li LANCOOL 216 ATX Mid Tower Case  (€95.85 @ Alternate)
Power Supply: *Corsair RM1000e (2023) 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (€139.90 @ Amazon Netherlands)
Operating System: *Microsoft Windows 11 Home OEM - DVD 64-bit  (€124.90 @ Amazon Netherlands)
Total: €2503.25
Generated by PCPartPicker 2023-12-12 21:17 CET+0100
A better look at those components.
https://www.asus.com/motherboards-components/motherboards/tuf-gaming/tuf-gaming-b650-plus/
https://www.amd.com/en/products/apu/amd-ryzen-7-7800x3d
https://www.deepcool.com/products/Cooling/cpuaircoolers/AK620-High-Performance-CPU-Cooler-1700-AM5/2021/13067.shtml
https://www.corsair.com/us/en/p/memory/cmh32gx5m2b6000z30k/vengeance-rgb-32gb-2x16gb-ddr5-dram-6000mt-s-c30-amd-expo-memory-kit-cmh32gx5m2b6000z30k
https://www.kingston.com/en/ssd/kc3000-nvme-m2-solid-state-drive
https://www.tomshardware.com/reviews/kingston-kc3000-m2-ssd-review
https://www.msi.com/Graphics-Card/GeForce-RTX-4080-16GB-VENTUS-3X-OC
https://www.corsair.com/us/en/p/psu/cp-9020264-na/rme-series-rm1000e-fully-modular-low-noise-atx-power-supply-cp-9020264-na
https://lian-li.com/product/lancool-216/
