iGFX problem
Go to solution Solved by Nixx23,
On 12/14/2023 at 10:42 PM, Nixx23 said:
Sooo should i give it to a experienced friend to check it out?
Well it turns out that there were false BIOS Settings. It wasn't MB or CPU thank god..
So i have 2 Monitors and i installed windows 10 because windows 11 is trash for me and since then the second monitor didnt work. I went into bios and i enabled iGFX and put the main display to PCie i think? and since then i cant get any signal on my monitor.. I tried removing cmos battery and placing it again but that didnt work aswell. Can somebody help me please (sorry for bad English)
https://linustechtips.com/topic/1546699-igfx-problem/
What are your full system specs?
Primary Gaming Rig:
Ryzen 5 5600 CPU, Gigabyte B450 I AORUS PRO WIFI mITX motherboard, PNY XLR8 16GB (2x8GB) DDR4-3200 CL16 RAM, Mushkin PILOT 500GB SSD (boot), Corsair Force 3 480GB SSD (games), XFX RX 5700 8GB GPU, Fractal Design Node 202 HTPC Case, Corsair SF 450 W 80+ Gold SFX PSU, Windows 11 Pro, Dell S2719DGF 27.0" 2560x1440 155 Hz Monitor, Corsair K68 RGB Wired Gaming Keyboard (MX Brown), Logitech G900 CHAOS SPECTRUM Wireless Mouse, Logitech G533 Headset
HTPC/Gaming Rig:
Ryzen 7 3700X CPU, ASRock B450M Pro4 mATX Motherboard, ADATA XPG GAMMIX D20 16GB (2x8GB) DDR4-3200 CL16 RAM, Mushkin PILOT 1TB SSD (boot), 2x Seagate BarraCuda 1 TB 3.5" HDD (data), Seagate BarraCuda 4 TB 3.5" HDD (DVR), PowerColor RX VEGA 56 8GB GPU, Fractal Design Node 804 mATX Case, Cooler Master MasterWatt 550 W 80+ Bronze Semi-modular ATX PSU, Silverstone SST-SOB02 Blu-Ray Writer, Windows 11 Pro, Logitech K400 Plus Keyboard, Corsair K63 Lapboard Combo (MX Red w/Blue LED), Logitech G603 Wireless Mouse, Kingston HyperX Cloud Stinger Headset, HAUPPAUGE WinTV-quadHD TV Tuner, Samsung 65RU9000 TV
https://linustechtips.com/topic/1546699-igfx-problem/#findComment-16243700
Can you check device manager to see if it shows up there under display adapters?
Primary Gaming Rig:
HTPC/Gaming Rig:
https://linustechtips.com/topic/1546699-igfx-problem/#findComment-16245005
Sorry, I misunderstood the issue initially. I thought the monitor didn't work on your motherboard outputs, not that you have absolutely ZERO displays working.
So let's back up a bit. What monitor(s) do you have, and to what specifically are each of them connected?
Primary Gaming Rig:
HTPC/Gaming Rig:
https://linustechtips.com/topic/1546699-igfx-problem/#findComment-16245013
Haha its ok i cant explain that good since my english is bad..
I have a LG Flatron M237WDP and a Samsung Syncmaster 2243 both of them are old.. I tried connecting one to gpu and one to motherboard and it didnt work (I have a dvi to hdmi converter for the syncmaster) But before i went to bios and made that stupid mistake enabling iGFX and setting display to PCIe everything worked fine..
https://linustechtips.com/topic/1546699-igfx-problem/#findComment-16245019
Let's start one step at a time by trying to rest your CMOS again. With power disconnected, you can either remove the battery, or jump the CLRTC pins just to the left or your USB headers. If you remove the battery, make sure you press the power button a few times to fully discharge the system.
After completing that, plug in ONE monitor to your GPU, turn on your system, and see if you can access the BIOS. Preferably, use a combination of monitor/cable that has no adapters if you can.
Primary Gaming Rig:
HTPC/Gaming Rig:
https://linustechtips.com/topic/1546699-igfx-problem/#findComment-16245133
I tried it again but it still doesnt work.. Its still the same. I tried it so many times but it didnt work. But idk why the keyboard only lights up for one second?? It wasnt like that.
https://linustechtips.com/topic/1546699-igfx-problem/#findComment-16245137
Does the system stay running, or does it totally shut down after 1 second?
Primary Gaming Rig:
HTPC/Gaming Rig:
https://linustechtips.com/topic/1546699-igfx-problem/#findComment-16245141
Let's hope it's something silly and not a motherboard issue. Go through your entire system and re-seat all your power cables, data cables, RAM, and GPU.
Primary Gaming Rig:
HTPC/Gaming Rig:
https://linustechtips.com/topic/1546699-igfx-problem/#findComment-16245161
Okay i will do that Tomorrow and i will Tell you if that worked. Thank you that you took your time for me👍
https://linustechtips.com/topic/1546699-igfx-problem/#findComment-16245168
Well i tried to reseat everything but still nothing.. I cant belive that one setting in bios made the whole pc go nuts
https://linustechtips.com/topic/1546699-igfx-problem/#findComment-16246347
Ok, let's start removing components. Pull your 1050ti out and use only the iGPU with one monitor.
Primary Gaming Rig:
HTPC/Gaming Rig:
https://linustechtips.com/topic/1546699-igfx-problem/#findComment-16246351
I already tried that and still nothing.. Is it maybe the PSU? Its wierd that my keyboard doesnt light up. Well it does but just one second
https://linustechtips.com/topic/1546699-igfx-problem/#findComment-16246354
Oh and i forgot to mention that i noticed that when i turn on my pc its not that loud anymore. What i mean is like when i turned my pc on before the fans were spinning faster (Changed that in Bios too)
https://linustechtips.com/topic/1546699-igfx-problem/#findComment-16246380
How are you resetting the BIOS, exactly?
When you turn it back on, have you tried waiting a little bit? Depending on the specific system, it will sometimes seemingly go through a boot cycle 2 or 3 times before POST-ing when you clear the CMOS or install a new CPU.
Primary Gaming Rig:
HTPC/Gaming Rig:
https://linustechtips.com/topic/1546699-igfx-problem/#findComment-16246591
I take the CMOS Battery out for like 5 Minutes and take the power cable out. And then i put the cmos battery back in and the power cable and then i power up my pc. I have waited for like 2 hours but nothing happend. I will order a new cpu maybe??
https://linustechtips.com/topic/1546699-igfx-problem/#findComment-16246600
I'd be more inclined to suspect the motherboard of fault, rather than the CPU. But I hesitate to recommend you start throwing parts at it.
Primary Gaming Rig:
HTPC/Gaming Rig:
https://linustechtips.com/topic/1546699-igfx-problem/#findComment-16246601
  • 1 month later...
