I need advice on sticky switches and flashing LEDs
Solved by OhioYJ,
As for them sticking if something got spilled on them or in them, it might be hard to clean them completely without taking the switches apart. After completely cleaning them with alcohol you may need to apply lube to them. Depending on the type of switch will depend on where and how much.
Personally it sounds like replacement switches are in order. Switches are relatively cheap, so trying a switch or two to see if it fixes the issue isnt a big deal if it's a keyboard you like. It's what I would try first. Honestly I would replace the switches rather than taking them apart even.
