Ok with my case i want this setup
4X120 THICK RAD x1
3X120 THICK RAD x1
1X120 MID RAD x2
RED TUBING
400ML TUBE RES
GTX 780TI BLOCK x2
PUMP
CLEAR COOLANT
but i cant find if the tubing i am thinking of getting will fit every thing
ANY THING
just make sure they are good for mid to high over clocks
what tubing will fir all of this?
https://linustechtips.com/topic/154614-some-help/
I would go for clear tubing and red coolant. stay with Mayhems for the cooling
i think he meant the tubing measures like in centimeters or inches idk :P
CPU: Amd fx 8120 3.9ghz...Motherboard: Asus m5a97 evo R:2.0...RAM: 8gb 1600 kingston hyperx blu...GPU: XFX R9 280x ...CASE: Nzxt h440...
HDD: Kingston adata ssd 500 gigs, wd blue 500gb...PSU: Corsair gs700...Monitors: Asus vk222h Cooler: Noctua nh-d14...Keyboard:coolermaster masterkeys m...Mouse: logitech g300...Headphones: Logitech g430
https://linustechtips.com/topic/154614-some-help/#findComment-2061511
