First PC
Solved by Dr. Will0hlep,
because the market changes quickly you are better off saving up the whole budget and buying everything at once. If you start buying stuff now, items you select at the start might lock you in to bad deals later.
Also, any advice you get now will be worthless in a weeks time due to change in pricing. Another issue will be new products being released which can't be prodicted now.
