After a bit of research for good components, I came up with this draft for a build that I will probably buy in December or January. I'll primarily be using it for 1440p gaming (MMOs, AAA games). My budget is around 1400€ and I'm ordering all of the parts from Germany. I used the site geizhals.de to compare prices, for reference.
I would love some feedback to see if everything is compatible, if there are any higher quality/cheaper parts to get or if the build is fine as it is.
https://de.pcpartpicker.com/list/w9nPXk
https://linustechtips.com/topic/1545769-first-pc-build-feedback/
Hello, I would go with something like this... I selected much better parts for your money, they will be much more durable and reliable for many years to come. I don't really like ASRock for Motherboards because they often look so cheap and a lot of people don't like the VRMs, BIOS, and RGB Software. I switched out the M.2 Drive for a much better one. It has more Speed has better longevity of 1,700,000 hours. I picked a better Case and Power Supply. The RAM I picked has a bit of RGB, it was a bit cheaper than what you had and if you don't like RGB then you can just turn it off with the RGB Software from MSI.
If you have any questions for me please ask and I can be reached here or if you prefer a quicker response then you can text me on Discord. Here is my Discord: Wizardsnapper#2772 . I can go over them in more detail if you need on there.
https://de.pcpartpicker.com/list/BDMQcH
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (€198.99 @ Mindfactory)
CPU Cooler: Thermalright Assassin King SE 66.17 CFM CPU Cooler  (€31.48 @ Amazon Deutschland)
Motherboard: MSI MAG B650M MORTAR WIFI Micro ATX AM5 Motherboard  (€189.90 @ Alza)
Memory: TEAMGROUP T-Force Delta RGB 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (€112.89 @ Alternate)
Storage: TEAMGROUP Cardea Zero Z440 Graphene 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (€107.89 @ Alternate)
Video Card: Sapphire PULSE Radeon RX 7800 XT 16 GB Video Card  (€539.00 @ Mindfactory)
Case: Fractal Design Pop Mini Air MicroATX Mid Tower Case  (€96.89 @ Amazon Deutschland)
Power Supply: MSI MAG A750GL PCIE5 750 W 80+ Gold Certified Fully Modular ATX Power Supply  (€113.90 @ Alza)
Total: €1390.94
I have been building PCs for over 30 years so if you have any questions please ask. For Future Communication I use Discord for much Faster Response Times as I have it open 24/7. I am also available if you need help before, during, or after the Build Process on Discord through Text,Voice, or Video Chat. I can be with you while you build your new PC if you need me to be. Here is my Discord: Wizardsnapper#2772
The only 2 changes id do is removing the cooler from the cost and getting a slightly cheaper SSD. Those 2 alone can afford us 2 more cores.
PCPartPicker Part List
CPU: AMD Ryzen 7 7700 3.6 GHz 8-Core Processor  (€324.99 @ Mindfactory)
Motherboard: ASRock B650M-HDV/M.2 Micro ATX AM5 Motherboard  (€135.98 @ Mindfactory)
Memory: G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (€133.89 @ Alternate)
Storage: Silicon Power UD85 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (€102.02 @ Amazon Deutschland)
Case: be quiet! Pure Base 500DX ATX Mid Tower Case  (€89.90 @ Amazon Deutschland)
Power Supply: Cooler Master MWE GOLD 750 V2 FULL MODULAR 750 W 80+ Gold Certified Fully Modular ATX Power Supply  (€100.00 @ Amazon Deutschland)
Total: €1425.78
Generated by PCPartPicker 2023-12-08 03:31 CET+0100
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
CPU: Intel Core i5-12600KF 3.7 GHz 10-Core Processor  (€214.87 @ Amazon Deutschland)
CPU Cooler: ARCTIC Freezer i35 CPU Cooler  (€23.90 @ Alza)
Motherboard: MSI PRO Z790-A MAX WIFI ATX LGA1700 Motherboard  (€284.90 @ Alza)
Memory: TEAMGROUP T-Force Delta RGB 32 GB (2 x 16 GB) DDR5-7600 CL36 Memory  (€176.89 @ Alternate)
Storage: KIOXIA EXCERIA G2 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  (€48.98 @ notebooksbilliger.de)
Video Card: XFX Speedster QICK 319 Core Radeon RX 7800 XT 16 GB Video Card  (€547.99 @ Mindfactory)
Case: Zalman R2 ATX Mid Tower Case  (€43.90 @ Alza)
Power Supply: SeaSonic G12 GC 750 W 80+ Gold Certified ATX Power Supply  (€86.89 @ Alternate)
Case Fan: ARCTIC F14 Silent 46 CFM 140 mm Fan
Total: €1428.32
OS: OpenBSD -current WM: Polybar -- bspwm -- dmenu -- picom Components: Intel 12700KF -- G.SKILL RIPJAWS @4000 CL18 -- ASUS Dual Radeon RX 9060 XT 16GB -- ASUS ROG STRIX B760-G GAMING WIFI D4 -- JONSBO Z20 black -- ARCTIC F14 -- bequiet! SYSTEM POWER 10 550W -- DeepCool AG500BK -- Kingston Renegade G5 1TB and Samsung 9100 PRO 1TB Mouse: zalman ZM-GM7 Display panel: UltraGear 34G630A-B Headphones: Kawai SH-9 Webcam: Microsoft LifeCam HD-3000 Keyboard: HP desktop 320K Microphone: Trust GXT 259 RUDOX Camera: Fujifilm X-M5
Very solid, I don't see a reason we need to change it. All light's green from me and when you build it you'll know yourself that it's your selection and you configured it correctly.
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
