I am looking for help to determine if using a hub to connect a Steamdeck to wired internet and a portorable display. I want to set it up so I only need to plug the USB c cord into the display. And have the hub provid power and networking to the deck and display. Is this posable? I can't seam to find any hubs that have a usb c out that can provide power and single to the display.
https://linustechtips.com/topic/1545606-usb-c-hub-question/
Something like this should do most of it. USB C video out isn't something you're going to find, at least unlikely.
https://www.amazon.com/Docking-Station-Compatible-Ethernet-Charging/dp/B0BQB8V29X?th=1
I just googled "Steam deck + USB C hub + ethernet and power" and that was the first hit.
Another
https://www.amazon.com/Anker-PowerExpand-Ethernet-Delivery-MacBook/dp/B08C9HZ5YT
Probably plenty more. Ton of useful information from existing users using that search as well.
https://old.reddit.com/r/SteamDeck/comments/zvm6e6/usbc_hub_recommendation_with_ethernet_and_power/
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
https://linustechtips.com/topic/1545606-usb-c-hub-question/#findComment-16236374
Another
Thank you for the help. The USB C video I thought was not going to be possible but I figured if anyone knew if it was posiable they would be here.
https://linustechtips.com/topic/1545606-usb-c-hub-question/#findComment-16237485
