Hello, I just wanted to ask a question. For budget air cooler for my 5600, should I go with a ID cooling or a thermal right Assassin spirit.
There both 16-18$ usd.
I would be using it for gaming/school work.
Or is there better 1 tower coolers out there for there for the same price.
(I will be using the one that comes with the CPU for a while intill I get some more money)
https://linustechtips.com/topic/1545433-cooling-cpu/
There are a few different ID Cooling models.
I doubt the Assassin Spirit can be beat at that price.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1545433-cooling-cpu/#findComment-16234999
Well, I was watching the Gamers Nexus best cpu coolers video.
https://youtu.be/ow0crBSKIXw?si=cwzbajCQWydOxTN_
And after looking at it for my use case. The lower wattage coolers for the cheaper for my budget system.
The Thermalright
Thermalright Assassin Spirit 120 V2
https://a.co/d/8IxfOjz
17$ USD
The ID-COOLING
ID-COOLING SE-214-XT ARGB  https://a.co/d/4YwOgit
18$ USD
I don't know if these are the best but, that's what I've picked so far. I think there better than the stock spire cooler that comes with the 5600.
I hope they can mount easily.
https://linustechtips.com/topic/1545433-cooling-cpu/#findComment-16235021
