Compatible cable for this Power supply.
Go to solution Solved by Poinkachu,
18 minutes ago, Abysmal said:
(Resolved) ---> don't pull a me and forget to look in your motherboard box for more cables lol.
Hi everyone I am needing some help on this issue. I am in the middle of my new build and I went with Seasonics Prim ATX 3.0-1600W 80+ Titanium for my power supply. I have a Samsung 870 QVO SATA lll SSD 8tb. That I would like to use. However, I did not know at the time that this power supply does not come with a SATA III data cable L shaped if that makes sense. Making me unable to plug in my ssd and use it. Is there some place I could buy one that’s compatible with this power supply or do I need to just buy a hole new power supply that comes with one. Any help would be apricated thanks! :).
Part that I need but don't know if its safe to use with my power supply.
 https://www.amazon.com/Benfei-Straight-Locking-Compatible-Driver/dp/B07JFQ2H9R/ref=pd_ybh_a_sccl_3/139-8962489-9485620?pd_rd_w=eTT9h&content-id=amzn1.sym.67f8cf21-ade4-4299-b433-69e404eeecf1&pf_rd_p=67f8cf21-ade4-4299-b433-69e404eeecf1&pf_rd_r=65EQEEKEP5VDFZD24V7S&pd_rd_wg=GTxt3&pd_rd_r=04337612-6bee-4428-b21f-2f2fd190a554&pd_rd_i=B07JFQ2H9R&th=1
My build for reference
AMD Ryzen 9 7950X3D 4.2 GHz 16-Core Processor
NZXT Kraken Elite 360 RGB 78.02 CFM Liquid CPU Cooler
MSI MEG X670E ACE EATX AM5 Motherboard
G.Skill Trident Z5 Neo RGB 64 GB (2 x 32 GB) DDR5-6000 CL30 Memory
Samsung 870 QVO 8 TB 2.5" Solid State Drive Can’t use as power supply comes with sata cables but not the data cable that’s L shaped.
Samsung 990 Pro w/Heatsink 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive
Samsung 990 Pro w/Heatsink 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive
Sapphire NITRO+ Radeon RX 7900 XTX 24 GB Video Card
Corsair 7000D AIRFLOW ATX Full Tower Case
SeaSonic PRIME TX-1600 ATX 3.0 1600 W 80+ Titanium Certified Fully Modular ATX Power Supply  L shaped cable needed that is safe to use with power supply.
Microsoft Windows 11 Pro OEM - DVD 64-bit
Lian Li Uni Fan SL-Infinity 61.3 CFM 120 mm Fans 3-Pack X3 packs
For future reference :
SATA data cable doesn't come with power supply (it comes with motherboard), nor there are any compatibility issue with power supplies.
Edited by Abysmal
https://linustechtips.com/topic/1544164-compatible-cable-for-this-power-supply/
Refresh before you reply
