Budget (including currency): $1500
Country: USA
Games, programs or workloads that it will be used for: Main games would be Warframe and Binding of Isaac. But my main concern is using CAD software like solidworks.
Other details:
Here is a list of my current PC parts. I thought I had a little more time to upgrade but all the components are slowly dying.
CPU: Intel Core i5-6600K 3.5 GHz Quad-Core Processor
CPU Cooler: Cooler Master Hyper T4 70 CFM Rifle Bearing CPU Cooler
Motherboard: MSI Z170A GAMING PRO ATX LGA1151 Motherboard
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-2666 CL16 Memory
Storage: Samsung 850 Evo 500 GB 2.5" Solid State Drive
Storage: Samsung 850 Evo 1 TB 2.5" Solid State Drive
Video Card: ASRock Radeon RX 6600 Challenger 8GB GDDR6 Graphics Card
Case: Corsair Carbide Series 200R ATX Mid Tower Case
Power Supply: EVGA SuperNOVA 850 G2 850 W 80+ Gold Certified Fully Modular ATX Power Supply
Optical Drive: LG UH12NS30 Blu-Ray Reader, DVD/CD Writer
https://linustechtips.com/topic/1543666-need-help-upgrading-my-pc/
Well, here's a quick recommendation for both gaming and CAD productivity apps, with some note:
Salvageable Parts
From the list, some parts that I think can be reused for the new builds are:
Video Card: ASRock Radeon RX 6600 Challenger 8GB GDDR6 Graphics Card (depending on the case)
CPU Cooler
Since the CPU I'm recommending are not very extensively require cooling, Cooler master Hyper T4 or stock Intel Cooler is good enough
Storage
Both Samsung 850 Evo SATA SSD can be reused for extra storage or cloned to the new NVME as the main OS and app directory
GPU/Video Card
ASRock RX 6600 is a really good card for gaming, you can reuse it for the new build and disregard of new GPU purchase, but if you want to buy new, RTX 4070 is quite a good choice, especially for CAD
PC Case
This case (pun intended) is interesting. Although the front side has early 2000 design, it does look very professional while providing slots for cooling (side fan and top fans looks cool). So you can reuse it if you want
PSU
EVGA SuperNova is a really good budget PSU, absolutely a beautiful beast, even after 9 years since initial launch
In my generalized opinion, if your PSU is over 7 years old of use, you may consider on changing it as the electrical components inside are becoming less efficient over time. But if you purchased and used this PSU in less than 5 years, I don't see the reasons to change it.
Additional Concern
For RAM size, it's either 16, 32 or 64 GB, depending on the project size of your CAD work
If it's a small scale or simple design, a basic 16 GB size is good enough
But in this case, I will say go to 32GB as the sweet spot of plenty enough but not extravagant unless you're handling a very big and important project
Assuming you're purchasing entirely new parts, here's my recommendation of the parts, with total budget of USD1359.85
PCPartPicker Part List
CPU: Intel Core i5-13600K 3.5 GHz 14-Core Processor  ($270.00 @ Amazon)
Motherboard: ASRock Z790 PG LIGHTNING ATX LGA1700 Motherboard  ($159.99 @ Newegg)
Memory: G.Skill Ripjaws S5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($104.99 @ Newegg)
Storage: Samsung 990 Pro 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($119.99 @ B&H)
Video Card: MSI VENTUS 3X OC GeForce RTX 4070 12 GB Video Card  ($524.99 @ Newegg)
Case: Lian Li LANCOOL 216 ATX Mid Tower Case  ($94.99 @ Newegg Sellers)
Power Supply: be quiet! Pure Power 12 M 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($84.90 @ Newegg Sellers)
Total: $1359.85
Generated by PCPartPicker 2023-11-26 21:00 EST-0500
My System: Ryzen 7800X3D // Gigabyte B650 AORUS ELITE AX // 32GB 6000MHz DDR5 Silicon Power Zenith CL30 // Sapphire Pulse AMD Radeon RX 7900 XT OC with mod heatsink on the metal plate  // Phanteks P300A  // Gigabyte Aorus GEN4 7300 PCIE 4.0 NVME // Kingston NV2 Gen4 PCIE 4.0 NVME //
Seasonic Focus GX-850 Fully Modular // Thermalright Frost Spirit 140 Black V3 // Phanteks M25 140mm // Display: Bezel 32MD845 V2 QHD // Keychron K8 Pro (Mod: Gateron black box ink; Tape mode on PCB and Keycaps) // Razer Cobra Wired Mouse // Audio Technica M50X Headphone // Sennheiser HD 650 // Genius SP-HF180 USB Speaker //
And Laptop Acer Nitro 5 AN515-45 for mobility
Phone:
iPhone 11 (with battery replaced instead of buying new phone for long term and not submitting (fully) to Apple Lord
CPU: *AMD Ryzen 7 7700X 4.5 GHz 8-Core Processor  ($279.98 @ Amazon)
CPU Cooler: *Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler  ($33.90 @ Amazon)
Motherboard: *MSI B650 GAMING PLUS WIFI ATX AM5 Motherboard  ($188.67 @ Amazon)
Memory: *G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($99.99 @ Newegg)
Video Card: *MSI VENTUS 3X OC GeForce RTX 4070 12 GB Video Card  ($524.99 @ Newegg)
Power Supply: *Corsair RM750e (2023) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($96.99 @ Newegg)
Total: $1224.52
Generated by PCPartPicker 2023-11-26 21:24 EST-0500
Salvageable Parts
CPU Cooler
Storage
GPU/Video Card
PC Case
PSU
In my generalized opinion, if your PSU is over 7 years old of use, you may consider on changing it as the electrical components inside are becoming less efficient over time. But if you purchased and used this GPU in less than 5 years, I don't see the reasons to change it.
Additional Concern
If it's a small scale or simple design, a basic 16 GB size is plenty enough
Assuming you're purchasing entirely new parts, here's my recommendation of the parts, with total budget of USD1349.85
Total: $1359.85
Thank you for the quick response! Regrading when I got the parts I got all of them 9 years ago (except the graphics card) and they have been in use the whole time. I find that the 16 gb of ram is always in use to at least 95-100% when I both CAD and play games so 32 gigs. My CPU is also my main bottleneck right now but that might be because it's almost a decade old.
Country: USA
Other details:
A 13th gen i5 would be an easy upgrade, but maybe also that gpu could use a solid upgrade too.
https://pcpartpicker.com/list/TVXJmD
CPU: Intel Core i5-13600KF 3.5 GHz 14-Core Processor  ($249.99 @ Amazon)
CPU Cooler: Noctua NH-D15S chromax.black 82.51 CFM CPU Cooler  ($109.95 @ Amazon)
Motherboard: MSI MAG B760 TOMAHAWK WIFI ATX LGA1700 Motherboard  ($179.99 @ B&H)
Memory: G.Skill Ripjaws S5 32 GB (2 x 16 GB) DDR5-6000 CL32 Memory  ($99.99 @ Newegg)
Storage: Samsung 850 Evo 500 GB 2.5" Solid State Drive  (Purchased For $0.00)
Storage: Samsung 850 Evo 1 TB 2.5" Solid State Drive  (Purchased For $0.00)
Video Card: Asus DUAL OC GeForce RTX 4060 Ti 8 GB Video Card  ($379.99 @ Newegg)
Case: Fractal Design Pop Air RGB ATX Mid Tower Case  ($89.99 @ B&H)
Power Supply: Corsair RM850x (2021) 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($129.99 @ Amazon)
$1359.88
Am I still to create the perfect system?! ~ Clu
Keep your expectations low, boy, and you will never be disappointed. ~ Kratos
Nice, it's cool to see tech well used for an extended period of time, and it's due to an upgrade anyway
Tech tips for GPU, you can try to make the new built without purchasing the new GPU.
After the built and you tried with the current RX 6600, if you feel it is slow / bottleneck (which likely would), you may then consider buy RTX 4070 or equivalent GPU
What is the difference between the Intel Core i5-13600K and the Intel Core i5-13600KF
13600K has integrated graphic, while 13600KF doesn't
So in the worst case scenario if your GPU somehow breaks, you can still use your PC by plugging the HDMI/DP cable onto your motherboard and use it to do some work (that is not GPU intensive)
Phone:
