Looking for help for first pc built
Is there a reason you want to stick with Intel? The AMD 7600 will likely have better performance while using less power than the 12600KF. I omitted the monitor from this parts list since you have that covered already. Also, the 7600 comes with a cooler. Since you will need less power, I picked a lower wattage power supply. This left enough money to upgrade the ram a bit. You could save money downsizing your case or SSD, but the ones you picked are good unless you needed ways to lower the total cost.
PCPartPicker Part List: https://nl.pcpartpicker.com/list/khhfh3
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor (€207.95 @ Megekko)
Motherboard: MSI B650 GAMING PLUS WIFI ATX AM5 Motherboard (€164.99 @ Paradigit)
Memory: G.Skill Ripjaws S5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory (€129.00 @ Azerty)
Storage: Crucial P5 Plus 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive (€103.09 @ Amazon Netherlands)
Video Card: Gigabyte WINDFORCE OC GeForce RTX 4070 12 GB Video Card (€619.00 @ Megekko)
Case: Antec DF700 FLUX ATX Mid Tower Case (€85.69 @ Amazon Netherlands)
Power Supply: Gigabyte UD750GM 750 W 80+ Gold Certified Fully Modular ATX Power Supply (€89.90 @ Amazon Netherlands)
Total: €1399.62
Generated by PCPartPicker 2023-11-24 03:12 CET+0100
