Hi. I'm building a new PC and have been looking for help on whether or not I'm wasting money(ei are there better components for that price) here is the PCpartspicker list: https://pcpartpicker.com/list/Tyy7vj
The only things set in stone are motherboard and case since I already own them
https://linustechtips.com/topic/1542491-pc-build-help-needed/
Can you tell us what you're going to use it for?  Games, productivity?  Resolution used?
Budget?
There is a template for this, btw.  In the forum you just used.
Short list:  RAM and SSD need changing.  RAM is way too high latency, get CL30.  SSD is 50% more expensive than it needs to  be, if you want to save money.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1542491-pc-build-help-needed/#findComment-16216583
looks pretty good, Id suggest you look a little more for the ram though, you can get the same stuff same speed but much better CL for $3 to $4 more, for instance
https://www.amazon.com/CORSAIR-VENGEANCE-6000MHz-Compatible-Computer/dp/B0BPTKD797/ref=pd_sbs_isce_sccl_2_3/138-2730003-1675364?pd_rd_w=hVp0g&content-id=amzn1.sym.76a43e74-638c-435a-8b14-0b22762b7f4a&pf_rd_p=76a43e74-638c-435a-8b14-0b22762b7f4a&pf_rd_r=A2RVPHVW9TK71JZAR8Z2&pd_rd_wg=FTFlv&pd_rd_r=74243102-f7e6-4bb7-a6ea-c65f73b6acc4&pd_rd_i=B0BPTKD797&th=1
This is the same thing but CL 30 and also AMD expo compatible, it will be faster plus already tested for its full speed with AMD
                          Ryzen 5800X3D(Because who doesn't like a phat stack of cache?) GPU - 7700Xt
                                                           X470 Strix f gaming, 32GB Corsair vengeance, WD Blue 500GB NVME-WD Blue2TB HDD, 700watts EVGA Br
 ~Extra L3 cache is exciting, every time you load up a new game or program you never know what your going to get, will it perform like a 5700x or are we beating the 14900k today? 😅~
https://linustechtips.com/topic/1542491-pc-build-help-needed/#findComment-16216588
Budget?
That's why I posted pc part picker list... budget would be around 1000-1300 since 'm locked into a motherboard... basically I was looking mostly if I needed to change anything other then cpu since everyone is telling me it's the best gaming cpu... resolution is 1440p
https://linustechtips.com/topic/1542491-pc-build-help-needed/#findComment-16216599
Thanks... will look for it
https://linustechtips.com/topic/1542491-pc-build-help-needed/#findComment-16216601
Try this
PCPartPicker Part List: https://pcpartpicker.com/list/yhzRz6
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor  ($359.00 @ Amazon)
CPU Cooler: Thermalright Phantom Spirit 120 SE 66.17 CFM CPU Cooler  ($35.90 @ Amazon)
Motherboard: ASRock B650M-HDV/M.2 Micro ATX AM5 Motherboard  ($109.99 @ Newegg)
Memory: G.Skill Trident Z5 Neo RGB 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($117.99 @ Amazon)
Storage: Samsung 990 Pro 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($119.99 @ Amazon)
Video Card: MSI VENTUS 3X OC GeForce RTX 4070 12 GB Video Card  ($524.99 @ Newegg)
Case: Fractal Design Focus 2 ATX Mid Tower Case  ($79.98 @ Newegg)
Power Supply: Corsair RM850e (2023) 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($114.99 @ Newegg)
Total: $1462.83
Generated by PCPartPicker 2023-11-22 09:32 EST-0500
Also a different NVMe, though not sure what to go for, market is a bit different here in UK
Price seems higher on the total there but that AIO is probably close to 100 dollars and not listed in the price so, better RAM, and a different cooler (can go RGB for an extra $2 if you want) for about or just under 60 quid less than original total
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
Case Fans: Fractal Prisma (120 x6, 140 x3) + 2x40mm fans
https://linustechtips.com/topic/1542491-pc-build-help-needed/#findComment-16216621
Look at a 7800XT or a 6950XT as well, more VRAM, with similar performance.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1542491-pc-build-help-needed/#findComment-16216623
1 minute ago, TatamiMatt said:
Try this
Total: $1462.83
Tell me about it... I'm croatian so most of the stuff I'll order is from amazon.de because shipping fees to Croatia from outside EU are insane
https://linustechtips.com/topic/1542491-pc-build-help-needed/#findComment-16216626
2 minutes ago, TatamiMatt said:
Try this
Total: $1462.83
I don't understand the top tier best SSD on the planet recommendations everyone does.  It's $40 more than an SSD you can't tell the difference of and gives 0 benefit for.
Use that savings on a better cooler or a better case.  Airflow matters.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1542491-pc-build-help-needed/#findComment-16216627
Definitely will... just put 4070 there for reference around what type of performance I'm looking for since I have 3060ti and I'm probably gonna hold onto it for a few months longer
https://linustechtips.com/topic/1542491-pc-build-help-needed/#findComment-16216631
I honestly put it there because it's samsung and from my personal experience they're reliable. Bit if you know of something else I'll gladly listen
https://linustechtips.com/topic/1542491-pc-build-help-needed/#findComment-16216636
Oh i just didnt change it as i wasnt sure of the availability of what was in his area, i do agree, something else would be just as good and much cheaper
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
https://linustechtips.com/topic/1542491-pc-build-help-needed/#findComment-16216648
Literally any other drive will be indistinguishable performance wise.  SSD's are paper fast.  Real world not as much.
If you put in this Gen 3 Silicon Power, you couldn't tell any difference even with benchmarks.
https://www.amazon.com/Silicon-Power-Gen3x4-Solid-SP002TBP34A60M28/dp/B07ZQ97H3W/ref=sr_1_6?crid=3NYRWK84VR8BN&keywords=2tb+nvme&qid=1700664837&sprefix=2tb+nvme%2Caps%2C80&sr=8-6&ufe=app_do%3Aamzn1.fos.17d9e15d-4e43-4581-b373-0e5c1a776d5d
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1542491-pc-build-help-needed/#findComment-16216653
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
https://linustechtips.com/topic/1542491-pc-build-help-needed/#findComment-16216659
