Idk if this is the right topic but il try.
I have a Odyssey g9 neo monitor that i love to play on, but i feel that it gives me disantvage in fps games.
Is there any smart way to setup a second monitor or arm so i can swap between a smaller monitor for fps gaming? This is my setup
https://linustechtips.com/topic/1542347-multiple-monitors-ideas-help/
I dunno if there is an easy way to change the positions of the monitors due to the sheer size of the G9. An obvious solution would be to get an L shaped desk though.
My PC Specs: (expand to view)
Main Gaming Machine
CPU:  Intel Core i7-14700K
CPU Cooler: Deepcool LT720
Motherboard: MSI PRO Z790-P WIFI
Memory: G.Skill Trident Z5 RGB 32 GB (2 x 16 GB) DDR5-6400
Storage 1: Samsung 990 Pro 2 TB
Storage 2: Crucial P3 Plus 4 TB
Video Card: EVGA XC3 ULTRA GAMING GeForce RTX 3080 10GB
Power Supply: Corsair RM850 850W
Case: Corsair 7000D Airflow
Case Fan 140mm: Noctua A14 PWM 82.5 CFM 140 mm (x7)
Monitor Main: MSI G274QPF-QD 27.0" 2560 x 1440 170 Hz
Monitor Vertical: Asus VA27EHE 27.0" 1920x1080 75 Hz
Hah did what u said, made a l shape 😅 not fully done yet tho
