hey there!
i'm looking for a black mouse that can emit white led backlighting or whatever you wanna call it. i'm looking for a mouse that fits nicely in medium to larger hands. i'm a casual gamer at best so extra buttons aren't important. i own a razor mamba which is ok but not really what i'm looking for, i dislike its lack of lighting and how it fits in my hand.
thanks for checking this thread out and helping!
Here is where I would keep my frolics if I had any.
https://linustechtips.com/topic/15423-white-led-mouse/
Take a look at steelseries, I think they have a couple with logos on the palm that light up white.
- Silverstone TJ08B-E - Gigabyte Z87M-D3H - i7 4770k @ 4.0GHZ 1.2v - 16gb Kingston HyperX Black 1600 - Gigabyte GTX 770 OC 4GB -
- Silverstone Fortress FT02 - MSI Z77 Mpower - i5 3570k @ 4.0GHZ 1.09v - 8gb Mushkin Blackline 1600 - MSI GTX 670 PE -
- Lenovo T430 (1600x900) - i5 3210m - 8GB DDR3 1333 - nVidia NVS5400M - 256GB mSATA OS - 320GB HDD-
https://linustechtips.com/topic/15423-white-led-mouse/#findComment-172709
https://linustechtips.com/topic/15423-white-led-mouse/#findComment-172710
Why focus on white when you have multiple colour selection? Back to topic, there are several mouse out there that allows you to select what colours you want your mouse to react. Well, this is just my preference, that's the reason I chose G600 over Razer Naga. They're both are fine and durability but I wanted customizable colours that never makes me bored.
PS : I'm a heavy multi-tasker with 30% gaming from now on due to works. Even the left mouse button starts to malfunction or double click, I can swap. I don't think it can swap but I can map them to any of the additional buttons on the mouse.
https://linustechtips.com/topic/15423-white-led-mouse/#findComment-172854
hey there!
My Razer Mamba 2012 can be set to display any color you'd like, and has the ability to cycle through the color spectrum.
https://linustechtips.com/topic/15423-white-led-mouse/#findComment-175337
