Help with upgrade path
Go to solution Solved by zvxnz,
3 minutes ago, sumerian said:
Thank your for the response ya i know either GPUs will bottleneck my current cpu. Im just worried that if i upgrade the cpu right now that my 2060 wont be good enough to get me through the next the next year before i can get a new gpu. I am looking at getting a 13600K when i do upgrade the gpu.
I understand your concerns, but the rtx 2070 is still a good gpu and I think it will be able to take you through the year if you were to play on 1080p, unless you are planning on playing gta 6 on max.
Hi there first time posting in the forum, looking for some possible advice with my upgrade.
current build -
i5-8600K
32GB ram
rtx2060
650watt PSU
Im looking at getting a new graphic card and upgrading the rest of the rig in about a year or so.
Ive been looking at either a rx6800($576can) or a 7800xt ($700can)
At the moment i am gaming at 1080 but looking at possibly move up to 1440 once i upgrade the CPU.
Will a rx6800 be good enough for the next 2years at 1080 or even 1440 or should i go with something better like the 7800xt
https://linustechtips.com/topic/1541821-help-with-upgrade-path/
If you were to upgrade the gpu first, the bottleneck would be very high even on the rx6800. If I were you, I would upgrade my cpu first. Its going to payback more if you don't have enough money atm. I'd suggest you to go with a 13th gen i5 or i7 cpu.
https://linustechtips.com/topic/1541821-help-with-upgrade-path/#findComment-16212456
Thank your for the response ya i know either GPUs will bottleneck my current cpu. Im just worried that if i upgrade the cpu right now that my 2060 wont be good enough to get me through the next the next year before i can get a new gpu. I am looking at getting a 13600K when i do upgrade the cpu.
https://linustechtips.com/topic/1541821-help-with-upgrade-path/#findComment-16212477
https://linustechtips.com/topic/1541821-help-with-upgrade-path/#findComment-16212491
