Latest Bios?
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1541752-cpu-ryzen-not-boosting/#findComment-16212072
Which stress test are you using to test with? If you're running at the default power limits in something like Prime95 for example it will run into those limits and more than likely run at or close to base clock. 4.2 is the rated single core boost clock, and it will not hit that when you're maxing out all cores in a stress test like Prime.
Main PC :
CPU = R9 3900X / Motherboard = Asus Crosshair 8 Hero / GPU = EVGA SC Ultra RTX 2060 / RAM = G.Skill 3600 16-19-19-39 ( 32GB / 4x8 ) / Cooling = Dark Rock Pro 4 / Storage = Western Digital Caviar Blue ( X4 ) Crucial 500GB NVME, 500GB 970 EVO/ PSU = Seasonic X-850 Modular / Case = Corsair Carbide 200R
Wireless = Asus PCE-AC56 / Keyboard & Mouse = Corsair K70 MX Blue, Logitech G203 / Headphones = Hyperx Cloud Alpha /
https://linustechtips.com/topic/1541752-cpu-ryzen-not-boosting/#findComment-16212098
try a cinebench (2024 and r23) and Aida 64
https://linustechtips.com/topic/1541752-cpu-ryzen-not-boosting/#findComment-16212107
I would expect a bit higher than 3.6 in Cinebench honestly, but I do believe R23 and 2024 are a bit heavier than older versions, so perhaps that's just your cpus limit in those workloads. What kinds of temps are you getting? You can try enabling PBO in bios to see if the higher power limits allow it to boost further, but you're probably going to max out around ~4GHz or so with default PBO. As a 3900x owner, I can tell you I see around ~4.15 GHz in Cinebench 2024 with PBO enabled, so I wouldn't expect a 3600 to hit much higher than that without manual overclocking. 3000 series just didn't clock that high to be honest. But you are hitting at least 3.6GHz which is the 3600's base clock, so it is running within spec. So as far as I know everything seems to be working as it should.
Definitely check your temps and try enabling PBO though, if you want a quick and easy way to get a bit of a boost that's where I'd start. I wouldn't bother overclocking with Zen 2 though to be quite frank. Any gains you may get would be negligible. Zen 2's biggest weakness was the split CCX design, and really no amount of realistic clock speed gain you'd get is going to offset that. That's where RAM and FLCK tuning comes into play, but that's a whole other thing entirely.
Main PC :
https://linustechtips.com/topic/1541752-cpu-ryzen-not-boosting/#findComment-16212124
