First PC Build, Need Help
Go to solution Solved by filpo,
Just now, boypuzzle said:
Would it be a better idea to get an ATX motherboard instead of a micro ATX one
yes but don't get the b650-p for $300 CAD. Instead get this one Gigabyte B650 AORUS ELITE AX ATX AM5 Motherboard (B650 AORUS ELITE AX) - PCPartPicker
2 minutes ago, boypuzzle said:
Here's the list based off of the questions I asked, would this pc still be good quality for the money paid for it?
yup, I'd say just swap out the mobo I linked just now
I'm looking at the last build you suggested, would it make sense to go with the RX 7800xt graphics card so that i could have more ram and similar frame rates, I'm not too concerned with ray tracing.
can you not use the 4070 for DaVinci resolve? That's just what I thought
Budget (including currency): 1500-1800 CAD
Country: Canada
Games, programs or workloads that it will be used for: streaming, god of war, switch games, sekiro, grounded, far cry 5, art applications (krita, photoshop), video editing (davinci resolve)
I'm making my first pc build and was wondering if these parts would make a good one https://ca.pcpartpicker.com/list/PkmdFs. I'll be streaming, gaming, and using art applications for the most part. It would also be nice to know if there's a certain time to buy the parts or if it's ok to get them asap. I would want resolution to be 1440 or 1080, i have some peripherals but they're not too high quality so some suggestions would be appreciated and can be separate from the tower cost. I have no existing pc parts because I'm upgrading from an Acer gaming laptop.Screenshot(12).thumb.png.46cda0ecf25c8399ccb1b50b44471f0a.png
https://linustechtips.com/topic/1541725-first-pc-build-need-help/
Welcome to the Forum!
it's private
is a monitor included?
mouse: Logitech G305 LIGHTSPEED Wireless Optical Mouse (910-006051) - PCPartPicker
keyboard: Redragon K596 Vishnu RGB Wireless Gaming Keyboard (K596) - PCPartPicker
Country: Canada
intel
without a monitor
PCPartPicker Part List
CPU: Intel Core i7-13700 2.1 GHz 16-Core Processor  ($468.98 @ Amazon Canada)
CPU Cooler: Thermalright Peerless Assassin 120 SE ARGB 66.17 CFM CPU Cooler  ($44.90 @ Amazon Canada)
Motherboard: MSI PRO B760-P WIFI DDR4 ATX LGA1700 Motherboard  ($189.99 @ Memory Express)
Memory: TEAMGROUP T-Force Vulcan Z 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory  ($74.97 @ Newegg Canada)
Storage: Crucial P3 2 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($86.68 @ Amazon Canada)
Video Card: Gigabyte WINDFORCE OC GeForce RTX 4070 12 GB Video Card  ($759.00 @ Canada Computers)
Case: Phanteks Eclipse G300A (1 Fan) ATX Mid Tower Case  ($64.98 @ Newegg Canada)
Power Supply: Thermaltake Toughpower GF1 PE 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($137.99 @ Amazon Canada)
Total: $1827.49
Generated by PCPartPicker 2023-11-19 09:27 EST-0500
AMD
Here's a build without a monitor for 1440p or 1080p
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor  ($481.99 @ Amazon Canada)
Motherboard: ASRock B650M-HDV/M.2 Micro ATX AM5 Motherboard  ($151.90 @ Vuugo)
Memory: G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL32 Memory  ($129.97 @ Newegg Canada)
Video Card: Asus DUAL GeForce RTX 4070 12 GB Video Card  ($756.98 @ Newegg Canada)
Total: $1855.39
Generated by PCPartPicker 2023-11-19 09:24 EST-0500
And a build with a 1440p monitor
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  ($264.99 @ Memory Express)
Monitor: MSI G272QPF 27.0" 2560 x 1440 170 Hz Monitor  ($249.99 @ Memory Express)
Total: $1843.48
Generated by PCPartPicker 2023-11-19 09:25 EST-0500
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
I'm looking at the last build you suggested, would it make sense to go with the RX 7800xt graphics card so that i could have more ram and similar frame rates, I'm not too concerned with ray tracing. Also i believe the RX 7800xt is cheaper where i am so i could put that money to a better case with more air flow like the 3 fan version of Phanteks. Would it be a better idea to get an ATX motherboard instead of a micro ATX one? I am willing to spend over 1800 for the tower itself and will pay more for any peripherals like the monitor separately from the budget for the tower. Here's the list based off of the questions I asked, would this pc still be good quality for the money paid for it? https://ca.pcpartpicker.com/list/38LkjH there's an image attached to this as well in case the link doesn't work again.
it's private
intel
without a monitor
Total: $1827.49
AMD
Total: $1855.39
Total: $1843.48
I'm looking at the last build you suggested, would it make sense to go with the RX 7800xt graphics card so that i could have more ram and similar frame rates, I'm not too concerned with ray tracing. Also i believe the RX 7800xt is cheaper where i am so i could put that money to a better case with more air flow like the 3 fan version of Phanteks. Would it be a better idea to get an ATX motherboard instead of a micro ATX one? I am willing to spend over 1800 for the tower itself and will pay more for any peripherals like the monitor separately from the budget for the tower. Here's the list based off of the questions I asked, would this pc still be good quality for the money paid for it? https://ca.pcpartpicker.com/list/38LkjH there should be an image attached to this as well in case the link doesn't work again.
Total: £1040.95
As of right now I'm not too concerned with DaVinci Resolve, I mostly put in on the list just to have a video editor on there, although it does seem that it should work fine. Other than that thank you very much for your help I hope you have a lovely day.
you too. good luck on the build!
Total: £1040.95
