3 minutes ago, overkill84 said:
I just got cpu from https://www.amazon.com/dp/B0BCF5CZ16?tag=pcpapi-20&linkCode=ogi&th=1&psc=1 When it came in I noticed the cpu inside plastic package been moving around inside box. Is this something I should be worried about or that's normal?
Seems fine likely just packaging being cheapest out on
https://linustechtips.com/topic/1541574-cpu-move-inside-box/#findComment-16211043
