Help with picking a GPU for an upgrade
3 minutes ago, xfrenki said:Thanks a lot for the suggestion!
I opened my PC up recently, and was looking for the 6/8 pin cable and was weirded out when I didn't find one, but I didn't realize that it was just completely missing, just thought I had lost myself in the ketchup and mustard mess.
I'm probably going to opt for what you suggested, but seeing how I can run a 130w card, maybe even a 140w, wouldn't it also work well for me to get a 3060, which has better performance, and is more useable for video editing, which I also need quite often, and just capping the wattage, so that it doesn't exceed it? Again I have no clue whether that's a good idea or not (or even if that is an idea but seems feasible)
I think it's important to state I was the person doing the mining, haha. I was using this app called Salad, which gave you in-app balance and you could then redeem it for other things. I used it for a long time and it was awful but I had to make do with it. My performance when I first got the card and the rig overall (2020) was way better than now, so I thought that the GPU's performance was influenced by the mining, but maybe it was just the years. Add to that, I don't even know whether or not the rig and the GPU were used before that. Of course, could just be the graphical advancements in games that affect my FPS but from what I've observed in the past few weeks, I seriously doubt that's the only reason.
Again, card degradation comes in the form of memory going bad not stutters/frame dropping. I really would suggest figuring out what is wrong with your current system, because it is fixable.
Another thing worth looking into is that it's not even the GPU at fault. The issues you described also can be caused by a virus/background program that is stealing CPU cycles.
