Constant Kernel Power Errors and BSOD
Go to solution Solved by Legendaryluck16,
1 hour ago, Catzzye said:
You can try reinstalling Fortnite because it seems it's anticheat is causing the bsod.
Could also be failing HDD/SSD or Windows.
Why exactly did you suspect of the PSU?
Good luck
My neighborhood experienced a power outage and after my pc would always randomly restart while playing fortnite, but not any other games. I asked for any solutions post and someone suggested the psu got damaged.
For the past two weeks I have been getting random kernel power errors while gaming, I attempted to resolve it by buying a new psu since i thought it could be to it being faulty. After installing the new psu today while playing fortnite I got my first BSOD. Im honestly lost on what could be the cause and desperate for any solutions. The BSOD reads Stop Code: KMODE Exception Not Handled    What Failed: EasyAntiCheat_EOSsys
https://linustechtips.com/topic/1541563-constant-kernel-power-errors-and-bsod/
Good luck
>> Please consider tagging me (with a @) or quoting my reply so I can more easily get back at you! <<
Always happy to help!! 🤠
Good luck
