PSU Advice
Go to solution Solved by Guest,
if the recommended psu is 1000w then get a 1000w psu because there might be some power draw spikes and might crash if the psu isn't powerful enough
at least from what i understood
10 minutes ago, jmac555 said:
Hi, this is my build I'm currently buying the parts for, just wondering if the 850W psu is enough for this as PCPartPicker is giving a 696W estimate, butASRock website recommends 1000w for the gpu.
https://au.pcpartpicker.com/list/wZDYWt
i would recommend to go higher than ASrocks recommendation. Maybe 1200w or 1600w.
Becuz the 7900xtx is a powerhungry GPU and can overload your PSU at times.
Pls Mark a solution as a solution, would be really helpful.
BTW pls correct me, iam really stoobid at times.
https://linustechtips.com/topic/1541241-psu-advice/#findComment-16208896
850w is enough for that build.  The 7800x3d doesn't pull much and the 7xxx series is more power efficient than the 6xxx.
God no, why?
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1541241-psu-advice/#findComment-16208898
God no, why?
7xxx series doesn't pull much power and it is more efficient. It gives better performance per watt, not less power draw.
So, 1200w should be good and go for 1600w if you really want too.
https://linustechtips.com/topic/1541241-psu-advice/#findComment-16208905
If you're phrasing it like that, then of course.
Since 850w is good...  1200w will be and 1600w will be, so get what you want.
Though the OP was asking more for what will be sufficient, rather than overkill.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1541241-psu-advice/#findComment-16208938
An 850W ATX 3.0 PSU should have no problems handling transients and would be a good choice. But following manufacturer guidance is always a good idea as it eliminates one possible issue if a warranty claim must be made.
https://linustechtips.com/topic/1541241-psu-advice/#findComment-16208977
An 850W psu is cutting it a bit close imo. A 1000W psu would be ideal for that build.
https://linustechtips.com/topic/1541241-psu-advice/#findComment-16208997
