Hello all,
I have a 6900XT and today my pc crashed while playing City Skylines 2.  When I booted back in I clicked on the Radeon taskbar item to open up the app, when I did I got a pop-up window that said my GPU was not compatible with the version of Radeon.  I did a full wipe/removal of the drivers, and then reinstalled them  Everything seems to be working with the exception of the temperature sensor.  I use Fan Control for my case fans and I use the GPU temperature sensor to control 2 of the fans.  However, when FC started up it spit back a sensor error and now the GPU sensor only reports -40 and 127.5 degrees, flip flopping back and forth.
Has anyone run into this and does anyone know if it is a GPU or mobo issue?
image.png.0e41954e673d17e9a4071c71b27d0fdf.png image.png.3944b85903862d434110d031299a9e5f.png
https://linustechtips.com/topic/1540427-gpu-temp-sensor-issue/
