Hi I have a problem with my new pc I had it for 5 months but today I try to boot it but I had no display and my all usb ports not working no power on usbs at all I try to remove ram didn’t work and there is a red light coming out of my motherboard the pc is brand new I have rtx 4070ti and 7 7800 razed I think but idk what going on if u can help me with it it will be awesome
I have attached my pc property
and just to let u know the pc was working perfectly fine without any problems like 5 hours ago
Edited by Keivan
https://linustechtips.com/topic/1539436-help-me-with-this-problem/
Sounds like your PSU has failed. That or your motherboard but that would be less likely. Especially such complete failure. What brand/model/wattage is your PSU?
Just now, Keivan said:
How to fix that bro
Replace it and see if it works again. Your system is fairly power hungry so you need a good quality PSU to power it reliably. One should always have good quality PSUs but especially with more power hungry stuff. Rated wattage means nothing really, quality of components (capacitors, etc) matters most and you need good quality and enough wattage. It could be that your PSU couldn't cope with the power draw.
1 minute ago, chtorogu said:
Well that sounds good but the 80 plus ratings aren't a guarantee of quality and there's also cheating going on with it. Do you know the brand and model?
Nope idk and idk how to open the pc I just trying to take out cables but they are not Evan coming off I was scared to broke something
5 minutes ago, Keivan said:
Impossible to see bro no chance
You'll need to remove the back panel then to see the PSU. That's very easy and safe. It should be attached at the back with some thumbscrews. Simply unscrew those and slide the back panel back and it'll come off. Replacing a PSU is also not that difficult and you need just do a web search for it and you'll find all the guidence you need. Or maybe you could get a friend to do it.
I was thinking to do it tomorrow going to shop to see the problem hopefully they can help me with it
What's the board's light label ? It should be named CPU, RAM, Graphics ("VGA") or Boot
Do the fans spin and light up (if RGB) ?
1 hour ago, Keivan said:
Yes they do spin and sometimes is cpu red one and sometimes is stuck in boot
Hmm then I'd rather suspect a CPU or BIOS issue than a PSU problem...
First reset CMOS
Reseat RAM sticks, using only 1 to start with
Use the board HDMI for video, remove the GPU
