PC Build help
Go to solution Solved by SorryBella,
1 hour ago, filpo said:
How much capacity is your old ssd and hdd?
Try this
PCPartPicker Part List
CPU: AMD Ryzen 5 5600 3.5 GHz 6-Core Processor  (€136.97 @ Galaxus)
CPU Cooler: Thermalright Peerless Assassin 120 SE ARGB 66.17 CFM CPU Cooler  (€38.29 @ Amazon Deutschland)
Motherboard: Gigabyte B550M DS3H Micro ATX AM4 Motherboard  (€89.61 @ Amazon Deutschland)
Memory: Silicon Power GAMING 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  (€35.99 @ Amazon Deutschland)
Video Card: Sapphire PULSE Radeon RX 6700 XT 12 GB Video Card  (€335.99 @ Mindfactory)
Case: Deepcool CC560 ATX Mid Tower Case  (€52.90 @ Alza)
Power Supply: EVGA 650 BQ 650 W 80+ Bronze Certified Semi-modular ATX Power Supply  (€63.02 @ Amazon Deutschland)
Total: €752.77
Generated by PCPartPicker 2023-10-21 09:57 CEST+0200
Motherboard: MSI B550 GAMING GEN3 ATX AM4 Motherboard  (€98.90 @ Alza)
Memory: TEAMGROUP T-Create Expert 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  (€61.89 @ Alternate)
Power Supply: Cooler Master MWE GOLD 750 V2 FULL MODULAR 750 W 80+ Gold Certified Fully Modular ATX Power Supply  (€109.90 @ Alza)
Total: €796.55
Generated by PCPartPicker 2023-10-21 11:11 CEST+0200
40 euros that can easily be recouped from pawning off that 1050 for something you can stick to.
Budget (including currency): 750 Euro
Country: Germany
Games, programs or workloads that it will be used for: CS2, Fortnite, F1, ETS2
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): Replacing my old 4 year old PC: Intel I3 9100F, GTX 1050ti 4gb, no peripherals needed, 144hz res I have the monitor.
Also, can I keep my old SSD and HDD and put them in the new PC?
https://linustechtips.com/topic/1536968-pc-build-help/
Country: Germany
Try this
Total: €752.77
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1536968-pc-build-help/#findComment-16176439
Try this
Total: €752.77
Total: €796.55
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1536968-pc-build-help/#findComment-16176467
Try this
Total: €752.77
240GB is the SSD and 1TB in the HDD. Thanks for the help
https://linustechtips.com/topic/1536968-pc-build-help/#findComment-16176497
Total: €796.55
Thanks
https://linustechtips.com/topic/1536968-pc-build-help/#findComment-16176499
