Processor: AMD Ryzen 5 3600 6-Core Processor
Video Card: NVIDIA GeForce RTX 2070 SUPER
Operating System: Windows 11
RAM: 16 GB
I recently upgraded to a Gigabyte  B550 Auros Elite v2 motherboard. I plan to upgrade my processor as well in the near future. I think a Ryzen 7 or an i7 will do. I don't know which generation will be the best. My usage is all my web development work plus casual gaming(but I need at least 1080p max gaming not to be an issue). Please let me know which should I upgrade to I want a cooler for it too. Right now, I have the Deepcool gammax l240 v2 rgb for cooling, will that work for the new processor or do I need to upgrade? Please suggest those options as well so I can start saving accordingly.
Also, I have a Gigabyte B700H 80 plus bronze. Do I need to upgrade it for the above two upgrades?
https://linustechtips.com/topic/1536381-need-advice-on-future-pc-upgrades/
get a ryzen 5700x or 5800X3D even (though I don't think you'll need it)
First update your bios then get the 5700x
Do you need 8 cores though? Or is it just better for you to have 8 cores?
I'd say you should as that isn't a very high quality unit
that should work for the 5700x
try this upgrade
PCPartPicker Part List
CPU: AMD Ryzen 7 5700X 3.4 GHz 8-Core Processor  ($169.99 @ B&H)
Power Supply: Thermaltake Toughpower GF1 PE 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($99.99 @ Newegg)
Total: $269.98
Generated by PCPartPicker 2023-10-17 12:25 EDT-0400
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
RAM: 16 GB
Why did you upgarde the  mobo first ? Makes no sense!!!
If you're moslty doing dev stuff get a 5950X
  • 2 weeks later...
Hi, I understand that. But unfortunately it wasn't a voluntary choice... I bought my PC in 2020. After 3 years now my B450 just gave up, and I had to urgently upgrade the mobo.
try this upgrade
Total: $269.98
Hey thanks you so much.
Can someone suggest other components as well which I can upgrade to? Like the GPU, the fans and the cabinet.
what's your budget?
I'd say go for this
CPU: AMD Ryzen 7 5800X3D 3.4 GHz 8-Core Processor  ($322.72 @ Amazon)
Video Card: XFX Speedster MERC 310 Radeon RX 7900 XT 20 GB Video Card  ($750.41 @ Amazon)
Case: Phanteks Eclipse G300A (1 Fan) ATX Mid Tower Case  ($34.99 @ Newegg)
Case Fan: ARCTIC P12 PST 56.3 CFM 120 mm Fans 5-Pack  ($30.31 @ Amazon)
Total: $1138.43
Generated by PCPartPicker 2023-10-31 04:05
Total: £1040.95
On 10/31/2023 at 1:35 PM, filpo said:
what's your budget?
I'd say go for this
Total: $1138.43
I am trying to upgrade this 3 year old PC gradually so just wanted to know which parts and in which order to go for.
Are these fans enough or do I need a liquid aio
For the 5800X3D? The use the deepcool gammax aio
Total: £1040.95
