Budget (including currency): 1500-2000 CAD
Country: Canada
Games, programs or workloads that it will be used for: Newer cod and battlefields, (hopefully) some vr through the quest 2, Red dead 2, Starfield, etc.
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc.): Just hoping I could get some help finding components, this would be my first build ever and I haven't really been following recent gpu or cpu development, I'm hoping to use pc part picker to throw it together but I honestly am not even sure where to start. I'd like the chipset to be intel but apart from that I'm none too picky, just would like something that is at least decently modern and can handle some newer titles.
https://linustechtips.com/topic/1536138-help-with-new-build/
https://pcpartpicker.com/list/fQ4vjH
i just threw this together, for now I would recommend if you want to go intel go with the 13700k in your budget but if you want to save a buck the 13600k is very good as well. I put in the Msi 240 Aio as a place holder, with either the 13700k or the 13600k I personally would recommend at least a decent 240mm Aio.
depending on your usecase and if you care about raytracing and productivity or not either go with the 6950xt for big d*CK gaming energy or a 4070 ti which will be a bit more expensive but will handle Ray Tracing and productivity better. 4070 ti will also be better with efficiency!
I left out a Case because that comes down to personal preference but with a big gpu like 6950xt make sure it’s a mid tower at least, I have the be quiet! Pure base 500dx and I like it a lot.
i didn’t catch if you need peripherals as well if so check how pricing is in your area and we can come back together and think on it.
https://linustechtips.com/topic/1536138-help-with-new-build/#findComment-16170658
Country: Canada
Do you own a monitor and if so what is the resolution and if not is the monitor to be included in the budget?
https://linustechtips.com/topic/1536138-help-with-new-build/#findComment-16170695
4 hours ago, Blackjack1336 said:
That's US PCPartPicker with USD pricing, $200 over budget if you switch to Canada.
240mm AIO's are pointless. Either get a 360mm AIO or save some money and get a tower one.
We don't even know if OP wants overclocking, or even needs it. No need to splash on a Z series board before we know anything.
@FueledCornflake, something like this would be pretty respectable:
PCPartPicker Part List
CPU: Intel Core i5-13400F 2.5 GHz 10-Core Processor  ($269.00 @ Amazon Canada)
CPU Cooler: Deepcool AG400 75.89 CFM CPU Cooler  ($34.99 @ Memory Express)
Motherboard: MSI B760 GAMING PLUS WIFI ATX LGA1700 Motherboard  ($199.99 @ Amazon Canada)
Memory: Corsair Vengeance RGB 32 GB (2 x 16 GB) DDR5-6400 CL32 Memory  ($159.99 @ Amazon Canada)
Storage: Crucial P5 Plus 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($94.21 @ Amazon Canada)
Video Card: Sapphire PURE Radeon RX 7800 XT 16 GB Video Card  ($748.97 @ Newegg Canada)
Case: Fractal Design Focus 2 ATX Mid Tower Case  ($99.98 @ Newegg Canada)
Power Supply: Thermaltake Toughpower GF1 PE 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($129.97 @ Amazon Canada)
Total: $1737.10
Generated by PCPartPicker 2023-10-16 04:57 EDT-0400
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
https://linustechtips.com/topic/1536138-help-with-new-build/#findComment-16170796
Though I do disagree with your opinion about 240mm Aios, your correct about wrong Pc part picker side and that the z motherboard is actually not needed yet, I just went for one I have good experiences with.
will try to improve
https://linustechtips.com/topic/1536138-help-with-new-build/#findComment-16171234
4 minutes ago, FueledCornflake said:
Hey thanks for the help! Ray tracing isnt really something i need to have but it would be nice, my monitors are also only 1080p
The 120mm fan goes inside the back of that case for a rear exhaust fan.
CPU: *Intel Core i5-13600KF 3.5 GHz 14-Core Processor  ($378.98 @ Amazon Canada)
CPU Cooler: *Deepcool AG620 67.88 CFM CPU Cooler  ($72.98 @ Newegg Canada)
Motherboard: *MSI B760 GAMING PLUS WIFI ATX LGA1700 Motherboard  ($239.99 @ Amazon Canada)
Memory: *ADATA XPG Lancer Blade 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($139.99 @ Canada Computers)
Storage: *Samsung 970 Evo Plus 2 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($149.85 @ Vuugo)
Video Card: *Sapphire 21330-01-20G Radeon RX 7800 XT 16 GB Video Card  ($699.99 @ Newegg Canada)
Case: *Fractal Design Focus 2 ATX Mid Tower Case  ($109.98 @ Newegg Canada)
Power Supply: *Corsair RM750e (2023) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($118.99 @ PC-Canada)
Case Fan: *ARCTIC P12 56.3 CFM 120 mm Fan  ($25.06 @ Amazon Canada)
Total: $1935.81
Generated by PCPartPicker 2023-10-21 16:29 EDT-0400
https://linustechtips.com/topic/1536138-help-with-new-build/#findComment-16177104
