Cut gpu fan splitter
6 minutes ago, Blackjack1336 said:Hi people!
I am currently building a low end pc out of a office Pc I got for free. I had to cut the shroud of the Asus Cerberus 1050 ti I got for the build so it would fit with the cpu cooler. Accidentally I cut the cable connecting both of the gpu fans. The gpu has one mini 4 pin header on the PCB. I can’t find a replacement cable online only mini 4 pin to Dual normal 4 pin wich wouldn’t fit the gpu fans. I have tried just twisting the cables back together but I’m just not capable enough to do so.
would love if anyone could help me find a replacement cable.
Have you tried twisting and then soldering? Alternatively, there are splicing connectors that encase the splice in both solder and plastic by heating it up.
