Cheap out on the motherboard if you can cuz that ain't gonna affect your peformance.
Go for DDR5 if you want max performance and DDR4 if you think that will do.
Go for a cheaper case so you can get better peripherals and if possible a better gpu.
I think a i5 13th gen should do because in minecraft single core speed count only matters.
go for this gpu instead, it is much cheaper. https://pcpartpicker.com/product/vTbTwP/zotac-gaming-trinity-oc-geforce-rtx-4070-ti-12-gb-video-card-zt-d40710j-10p
Those tips should give you a cheaper system so you can fit more things in (maybe get a better gpu (shhh dont teell anyone...)).
Pls Mark a solution as a solution, would be really helpful.
BTW pls correct me, iam really stoobid at times.
Most optimal for I assume 1080p 144hz~:
PCPartPicker Part List
CPU: Intel Core i5-13400F 2.5 GHz 10-Core Processor  ($206.99 @ Best Buy)
CPU Cooler: Thermalright Silver Soul 135 82 CFM CPU Cooler  ($34.90 @ Amazon)
Motherboard: MSI B760 GAMING PLUS WIFI ATX LGA1700 Motherboard  ($159.99 @ Amazon)
Memory: TEAMGROUP T-Create Expert 32 GB (2 x 16 GB) DDR5-6400 CL32 Memory  ($94.99 @ Amazon)
Storage: Crucial P5 Plus 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($53.99 @ Amazon)
Video Card: Gigabyte AORUS ELITE GeForce RTX 4070 Ti 12 GB Video Card  ($779.99 @ Newegg)
Case: Fractal Design Pop Air ATX Mid Tower Case  ($79.99 @ B&H)
Power Supply: Thermaltake Toughpower GF1 PE 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($99.99 @ Newegg)
Total: $1510.83
Generated by PCPartPicker 2023-10-10 09:31 EDT-0400
Get Windows from a reseller for $20. Only downside is it'll be linked to that PC only and can't transfer it.
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
