Printer Issues
Solved by Dedayog,
10 minutes ago, gwapongharjin said:Printer is not working
I tried printing a test page and here is the result.
I cleaned the print head and it just got worse instead of streaks only the outline of texts are shown.
What does this mean? I am unable to troubleshoot with different print heads and I just want to know what I need to replace for this is this just the print head?
Probably new ink, it's not flowing properly. Also, the print heads aren't fully cleaned. Keep running that cycle, as dried ink isn't a 1 and done cleaning.
