Building my 1st gaming pc and on part picker its saying that i need A USB 2.0 to USB 3.2 Gen 1 header adapter is required & a USB 3.2 Gen 1 to USB 3.2 Gen 2 header adapter is required
 Any one know what that is???
I Have a Lian LI Lancool 205 ATX Mid Tower Case & A MSI PRO-H610M-G MotherBoard
https://linustechtips.com/topic/1534200-need-help/
Lian LI Lancool 205 ATX Mid Tower Case uses USB 3.2 Gen 2 headers on front panel,
if the Motherboard doesn't have USB 3 connnector, it won't be able to connect to front panel USB headers (everything else would work, except front USB connectors)
which pcpartpicker might be wrong,
see if your motherboard has it, it should look like this:
current PC:
PC configs I used before:
https://linustechtips.com/topic/1534200-need-help/#findComment-16157145
