Hi all,
Basically this has been a recurring thing and basically can't really get my head around it now. Basically when I'm using my pc my tpm will stop i guess being enabled..? Unfortunately when I run tpm.msc in the run command box it brings me an error code 'Cannot load management console' (picture linked below) but it's a bit hit and miss. I have tried disabling and renabling but still no luck even swapping the cmos battery.
Does anyone else have any help for why or how to fix this?
https://linustechtips.com/topic/1534048-tpm-help/
18 minutes ago, FireLegend said:
Hi all,
Do all of your componets support TPM? Is TPM enabled. Has this issue been going since you have done something to youre computer? we need more context.
Intel Core i7 11700F + EVGA FTW3 ULTRA GAMING RTX 3070 OC + 32GB DDR4 3000Mhz RAM + ASROCK Z590 Steel Legend WIFI 6E + Razer Hanbo 360mm AIO + Corsair RM850X + Deepcool CH510 Case + Acer Nitro XV271 280hz Gaming Monitor
https://linustechtips.com/topic/1534048-tpm-help/#findComment-16155861
I think my components support tpm, are we talking cpu and motherboard then yes. I have gone in the bios and it's always enabled. Basically it's been going on ever since I got my new ssd and I wanted to see what windows 11 was all about.
Specs:
CPU - Ryzen 7 2700x
GPU - RX 580 8GB
Mobo - Gigabyte aourus b450 pro
RAM - Corsiar vegenance 16gb 3000MHz
SSD - Samsung 980 1tb (Windows C Drive)
HDD - Barracuda 1tb
PSU - ROG STRIX 750W 80+ GOLD
https://linustechtips.com/topic/1534048-tpm-help/#findComment-16155882
