I'm trying to pick a good CPU for gaming, and I'm considering between the i5-13400F and the Ryzen 7 5800x. Which one would you recommend? Also, are the Ryzen 5 5600 and 5600x good alternatives?
For the graphics card, I'm going for an RX 6600, and I'm starting with a single 16GB RAM stick, with plans to upgrade to 32GB in the near future.
What would be your suggestion for my setup?
https://linustechtips.com/topic/1534009-help-choosing-the-right-cpu/
is it just for gaming? If so then I would actually get the ryzen 5 7600 and a ddr5 system
The 5600x would be my choice in the US since the 5600 is actually more expensive than the 5600 right now and if it's just for gaming you won't need those extra cores on the 5800x or the extra e cores on the 13400f since those mostly help in productivity
What's your full budget btw?
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
My budget is around 600-650$ also I prefer a DDR4 system as it fits my budget also what if I get something like a Ryzen 5 7600x paired with a 6650xt or is that too much and the Ryzen 5600x or 5700x enough?
is your budget just for the cpu, mobo, ram and gpu?
Ryzen 5 7600x
ryzen 7000 can only be paired with ddr5
the ryzen 5600x is enough
try this
CPU: AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor  ($148.99 @ Newegg)
Motherboard: MSI B550-A PRO ATX AM4 Motherboard  ($129.99 @ Amazon)
Memory: Silicon Power GAMING 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($50.97 @ Amazon)
Video Card: PowerColor Fighter Radeon RX 6700 XT 12 GB Video Card  ($319.99 @ Amazon)
Total: $649.94
Generated by PCPartPicker 2023-10-02 12:50 EDT-0400
Total: £1040.95
try this
Total: $649.94
Oh wow this looks good, I think this might be it Thank You!
