https://ca.pcpartpicker.com/list/hgnQDZ
the system works fine for a week.
today when i turn it on, i had no video, no keyboard, nothing
on the motherboard, the DRAM light and CPU light stay on
i check the memory it was in all the way
it work again after a clear CMOS
after saving setting, same problem
did another clear, work again
i have the problem only when i set the memory EXPO setting to 6000
but it work fine for a week at 6000, strange
https://linustechtips.com/topic/1533940-strange-memory-problems/
memory overclock has always been finicky.
I'd start with giving memory controller a bit more votage
If that doesn't work, you'd likely have to tweek the memory settings manually.
This is quite common when ever a new generation of memory is introduced.
how do i tweek the memory settings manually ?
what settings and what values ?
edit :
the is a new bios 1.30 beta released today https://www.asrock.com/mb/AMD/X670E Pro RS/index.asp#BIOS
will that help ?
i currently have 1.28, i updated it after i installed windows to fix AMD PSP drivers
