Startup programs are not starting.
Solved by Sawa Takahashi,
7 minutes ago, NextraMia said:but it worked perfectly yesterday, I didn't do anything windows file related either
Automatic updates are sneaky like that.
5 minutes ago, NextraMia said:but tbh I have a lot of things that aren't needed anymore. I also have a weird problem with my monitor where it starts in a super bad resolution, I can change it back to 4k but it can't go above 60hz. When I unplug and plug in the DP cable it works as normal again, my computer has a fair share of problems haha!
You may try to DDU the video drivers and install them back but I suggest your clear your many glitches with a new fresh install
Have a nice day !
