Rx 6600m driver issue
Extnct23145
Go to solution Solved by 191x7,
24 minutes ago, Extnct23145 said:
I have an msi alpha 15, R 5800h and Rx 6600m. So I reinstalled my windows and did all the driver stuff. I went to the amd website and downloaded my GPUs drivers from and website and installed the latest ones which are currently 23.9.3 downloaded the adrenaline file cause the auto detect thing doesn't work for me always gives me an error. Anyways after installation the PC still wouldn't recognize the GPU and only after I uninstalled the drivers using DDU and installed the drivers from the msi support section, which are an year old,  did it pick up the GPU . The problem is even if I update it again from the amd website it doesn't work, my games still perform according to the old drivers. Absolutely made me hate amd. Please help me out cause I just bought this laptop and the old drivers are bad, they over heat the cpu and can't play rdr 2. Thanks.
You skipped a step.
The first thing you need is the driver for the iGPU on the CPU
https://www.amd.com/en/support/apu/amd-ryzen-processors/amd-ryzen-7-mobile-processors-radeon-graphics/amd-ryzen-7-5800h
Then you need the chipset drivers:
https://www.amd.com/en/support/chipsets/socket-fp5-mobile/amd-ryzen-and-athlon-mobile-chipset
And then the driver for the 6600M
https://www.amd.com/en/support/graphics/amd-radeon-6000m-series/amd-radeon-rx-6000m-series/amd-radeon-rx-6600m
Not necessarily in that order.
Can you share HWID for both Radeon GPUs?
You need to contact AMD for support...
I've been using computers since around 1978, started learning programming in 1980 on Apple IIs, started learning about hardware in 1990, ran a BBS from 1990-95, built my first Windows PC around 2000, taught myself malware removal starting in 2005 (also learned on Bleeping Computer), learned web dev starting in 2017, and I think I can fill a thimble with all that knowledge. 😉 I'm not an expert, which is why I keep investigating the answers that others give to try and improve my knowledge, so feel free to double-check the advice I give.
My phone's auto-correct is named Otto Rong.🤪😂
You skipped a step.
M.S.C.E. (M.Sc. Computer Engineering), Senior IT advisor in a hospital, 30 years of gaming, 20 years of computer enthusiasm, Geek, Trekkie, anime fan
  • Main PC: AMD Ryzen 7 5800X3D - EK AIO 360 D-RGB - Arctic Cooling MX-4 - Asus Prime X570-P - 4x8GB DDR4 3200 HyperX Fury CL16 - Sapphire AMD Radeon 6950XT Nitro+ - 1TB Kingston Fury Renegade - 2TB Kingston Fury Renegade 1TB  - 512GB ADATA SU800 - 960GB Kingston A400 - Seasonic PX-850 850W  - custom black ATX and EPS cables - Fractal Design Define R5 Blackout - Windows 11 x64 2022 - 3 Arctic Cooling P14 PWM PST - 5 Arctic Cooling P12 PWM PST
  • Peripherals: LG 32GK650F - Philips 226VL - Logitech G Pro X Superlight with Tiger Ice - HyperX Alloy Origins Core (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus RT-N18U - SpeedPort Plus - 35/7 Mbps vDSL - TP-Link TL-WA850RE - TP-Link 5-port 1Gbps switch
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Streaming/Server/Storage PC: AMD Ryzen 5 3600 - LC-Power LC-CC-120 - MSI B450 Tomahawk Max - 2x4GB ADATA 2666 DDR4 - 120GB Kingston V300 - Toshiba DT01ACA100 1TB - Toshiba DT01ACA200 2TB - 2x WD Green 2TB - Sapphire Pulse AMD Radeon RX 5700XT - 550W EVGA G3 SuperNova - Chieftec Giga DF-01B - Logitech G710+ - Roccat Kone Pure Military Desert strike - Logitech S-220
4 hours ago, 191x7 said:
Thanks I'll give this a try
Sorry but what is that ?
Hardware ID, can be found in the device manager and some other tools.
5 hours ago, 191x7 said:
Bro I did this and now the both GPUs are detected but when I play any game it uses the apu instead of the dedicated gpu
Screenshot(3).thumb.png.8251d4de56eecedc5757922d760a10fb.pngScreenshot(2).thumb.png.9cdf6afa628249e0814cffac0134ca9e.png
6 hours ago, 191x7 said:
Brother you are a life save, it all works now. 2 days of trying my own thing and nothing worked. Love you bro.
Does it still do this? Maybe change your power profile?
No brother it's all fixed now. Thank you
