Build Advice
Go to solution Solved by Why_Me,
Change your RAM to AMD Expo and look for a case with more fans. The 120mm fan goes inside the back of that case for an exhaust fan.
PCPartPicker Part List
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor  ($389.00 @ Amazon)
CPU Cooler: *Deepcool AG620 67.88 CFM CPU Cooler  ($49.99 @ Amazon)
Motherboard: Gigabyte B650 GAMING X AX ATX AM5 Motherboard  ($179.99 @ Amazon)
Memory: *G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($96.99 @ Amazon)
Storage: Samsung 970 Evo Plus 2 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($94.70 @ Amazon)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200 RPM Internal Hard Drive  ($57.99 @ Amazon)
Video Card: Asus TUF GAMING OC GeForce RTX 4070 Ti 12 GB Video Card  ($849.99 @ Amazon)
Case: *Fractal Design Focus 2 ATX Mid Tower Case  ($79.98 @ Newegg)
Power Supply: Corsair RM750 (2019) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($214.99 @ Amazon)
Case Fan: *ARCTIC P12 56.3 CFM 120 mm Fan  ($8.49 @ Amazon)
Custom: Windows 10 Pro OEM Key (Kinguin) ($30.42)
Total: $2052.53
Generated by PCPartPicker 2023-09-27 03:57 EDT-0400
A better look at that RAM, cooler and case.
https://www.gskill.com/products/1/165/396/Flare-X5-DDR5-AMD-EXPO
https://www.deepcool.com/products/Cooling/cpuaircoolers/GAMMAXX-AG620-Dual-Tower-CPU-Cooler-1700-AM5/2022/15900.shtml
https://www.fractal-design.com/products/cases/focus/focus-2/black-tg-clear-tint/
Budget (including currency):
Country: 2000-2300 USD
Games, programs or workloads that it will be used for:  Simply put Gaming. Ex. Cyberpunk, starfield, bg3.
Other details:
I am planning to essentially start over with my pc. The only things i may be keeping from my prior build is the 750w Power supply and the recently purchased 4070 Ti. I would appreciate any critiques with reasons to help me understand where i may be going wrong.
Current planned parts list - https://pcpartpicker.com/list/bMZvfy
Prior build/current pc. - https://pcpartpicker.com/list/rykPhg
https://linustechtips.com/topic/1533214-build-advice/
Looks tidy! Should be everything you need, would you consider an SSD instead of a HDD as it will run faster and last longer for not much more, that NVME will be your driving force though so if not for the SSD the HDD will be perfectly adequate! If you have the extra cash, youve said 2000-2300 and the PSU and GPU you already have take up 1k of the part pickers 2K cost, does this mean you have 1k to spare? maybe up the RAM? nothing too serious but possibly something like
2x24gb corsair vengeance 6400MHz CL36
Which is another 16gb, faster clock speed and the same latency for a hair extra
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
Case Fans: Fractal Prisma (120 x6, 140 x3) + 2x40mm fans
https://linustechtips.com/topic/1533214-build-advice/#findComment-16149583
Total: $2052.53
https://linustechtips.com/topic/1533214-build-advice/#findComment-16149590
Total: $2052.53
Does the 4000D airflow not have the fan same capacity as the focus 2?
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
https://linustechtips.com/topic/1533214-build-advice/#findComment-16149599
The 4000D comes with a single 120mm front intake fan and a 120mm rear exhaust fan. The Fractal Design Focus 2 comes with 2x140mm front intake fans.
https://linustechtips.com/topic/1533214-build-advice/#findComment-16149633
Ah i get you now, though with a build like that, @Jeffrey_Barney could fire in a few extra fans to the case anyway
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
https://linustechtips.com/topic/1533214-build-advice/#findComment-16149654
I would honestly dump the HDD if it'd a gaming pc , they don't belong on a relatively high budget gaming pc.
CPU : Ryzen 7 7800X3D @ -30mv All core
CPU Cooler : Thermalright Frozen Prism 240mm AIO
Mobo : Asrock B650m Pro RS Wifi
Ram : 32GB (2X16GB) Lexar Ares 6000MHZ CL 28-36-36-68
GPU : MSI Gaming X Slim 4070Ti Super 16GB ( 308W PL +140 Core +1000 Memory )
Storage : 2TB Verbatim Vi5000 Gen 4 NVME
PSU : Thermalright TG-750w 80+ Gold ATX 3.0 PCIE 5.0
Case : Fractal Design Pop Mini MATX
Case Fans : 3 X Thermalright TL-C12C-S RGB
Monitor :27" Samsung Odyssey G5 2560 x 1440 180 HZ IPS
Keyboard : HyperX Alloy Core RGB
Mouse : Corsair M65 Elite RGB
Headset : Corsair HS35 Gaming Headset
https://linustechtips.com/topic/1533214-build-advice/#findComment-16149665
I mean, for storing odd bits and bobs not needed for fast access its a decent, viable solution. I play dnd on my gaming rig and keep all files, images etc on a HDD as i dont need them to be instant access. Ik op specified gaming, if its for solely gaming and not a drop else then i agree but otherwise price to capacity its a good option.
But @Jeffrey_Barney if youre doing nothing else that wouldnt care about slower storage then yes, id also recommend a good SSD in place of the HDD, or even get another NVME for handiness sake, either a higher tier and swap that 2TB into a storage instead of a workhorse. Or go for like a slower much cheaper NVME thats cheap for the capacity but will still leave an SSD in the dust, for honestly the same price
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
https://linustechtips.com/topic/1533214-build-advice/#findComment-16149669
The problem is he could spend another $30 and get a 2TB m.2 instead , even less if you throw in a sata drive.
I only really see harddrive viability when you get to extreme levels of storage density.
The days of having to spend 4-5 times as much for a SSD are over.
https://linustechtips.com/topic/1533214-build-advice/#findComment-16149671
Edited comment just before you posted but fully agree 😋
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
https://linustechtips.com/topic/1533214-build-advice/#findComment-16149675
The Fractal + 120mm exhaust fan comes in at 88.47. The 4000D cost 104.99 before adding another front exhaust fan.
2x140mm > 2x120mm
https://linustechtips.com/topic/1533214-build-advice/#findComment-16150090
