Some say the Corsair AF are what you should use however I've seen a quote of something published by Corsair saying to use the SP's. If your mind isn't set on the Corsair fans, might I suggest Noctua NF12's if you can get past their color scheme otherwise Scythe GT's.
https://linustechtips.com/topic/1532-c70-front-panel-fan-question/#findComment-20956
roll with the SP120 fans. now your descision will be quiet or performance.
i use the PE and if needed, will undervolt to suit noise level goal.
yes, due to the filter and air-flow restrictions behind the fans, the SP
would be a better choice. therear exhaust and HDD cage fans would be
AF candidates, but for looks, matching SP would not hurt.
airdeano
https://linustechtips.com/topic/1532-c70-front-panel-fan-question/#findComment-21132
You should use SP's if the fans are right up against a restrictive HDD cage, other than that AF's will be fine
Corsair 600T White | Gigabyte Z77-UD3H | Intel Core i5-2500k | 8GB Gskill Ares@1600MHz | Gigabyte G1 GTX970 | OCZ ZT 550 | Western Digital Caviar Blue 500GB | Western Digital Caviar Black 1TB | Samsung 840 EVO 250GB (boot) | Full Custom Loop | NZXT HUE
https://linustechtips.com/topic/1532-c70-front-panel-fan-question/#findComment-21220
