I have a msi B85-G41 PcMate motherboard I updated the bios and it completed it shut off after the update but never came back on and now all the USB ethernet and USB / front case USB don't work it's like there not even there and it sounds like everything starts up fine but the motherboard won't do anything..
Edited by Alexander_9688
https://linustechtips.com/topic/1531179-help/
Unplug ALL external devices from your computer. (ALL)
Wait for a minute, then remove the button (cell) battery (carefully, don't pry it and accidentally score the motherboard or other components with a screwdriver) from the motherboard.
Wait for two minutes (don't skip this!)
Plug the button battery back in (the right way around!)
Plug the power and the screen (no more items!) back in
Turn on the computer.
https://linustechtips.com/topic/1531179-help/#findComment-16135140
12 hours ago, planetary problem said:
that will just bios reset, if he has a CPU newer than the newest CPU it supports, you may end up with MORE problems than that solves
Nope, this will not "revert" to an incompatible/older BIOS - it will NOT cause more issues.
https://linustechtips.com/topic/1531179-help/#findComment-16135951
Please click the "Thumbs Up" on any volunteer's post to thank them if they helped .(lower left, just to the right of My Computer )
https://linustechtips.com/topic/1531179-help/#findComment-16135970
8 hours ago, Alexander_9688 said:
I have removed  the cmos all ready the only part I haven't done is disconnect all the drives would that make a difference.
try using a secondary display output, maybe its your GPU dying in the most inconvenient time, and when you turn on your PC, do the fans spin, or does nothing happen?
https://linustechtips.com/topic/1531179-help/#findComment-16136385
