I have a issue i want to place a exaust fan on to the top of the case so i can cool my ram down and get hot air out of the case, the cooler is a thermalright assasin 120 se and has 2 120 mm fans on it and when i try to place the fan the heatsink is in the way so when the fan spins it hits the heatsink. Any ideas on how i can use the fan in exaust on the top of the case?
https://linustechtips.com/topic/1530459-ram-and-cooling-problems/
What case?  Can you post a pic?  Other fans?
Seriously doubt your RAM is overheating though.
Also, this is in the Audio subforum, may not get the attention.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
Just now, Eskil28 said:
I have a msi mid case i dont remember the exact name lemme look it up, its like a msi mag case i can send a picture wait.
My ram is currently at 61 celcius which i consider hot.
Understood but DDR4 for example is good til 80c or so.
Why you're checking your RAM temps is a bit much, are you running into any issues?
OnePlus Ecosystem:
3D Printing:
61c is perfectly fine.  nothing to worry about.
Just now, Somerandomtechyboi said:
If you are overclocking then ram temps definitely matter (atleast for proper overclocks) but if you arent you can just let em hit whatever temp
I’m using xmp that’s all I got Corsair venegrance 3600 mhz.
I want my exhaust fan here but it’s touching the heatsink when I spin it with my finger.Can I zip tie the fan on there?
What do you mean by zip tie?  Don't you have screws for the fan, from the top?
Honestly though, the CPU Cooler having 2 fans is doing as much work to get warm air from off the RAM, the top fan won't do much right there.
OnePlus Ecosystem:
3D Printing:
Xmp is not what id consider an actual overclock, its just rated speedbin of the ram thats outside of jedec spec
At such slow <4400 speeds ram temp is pretty much the last thing you need to worry about especially when its just some generic xmp bin. Only exception being overclocked samsung b die or whatever other really temp sensitive ic but most ics arent gonna be that temp sensitive and with how conservative xmp usually is you really have nothing to worry about even if you do get a temp sensitive ic
I personally prefer <40c ram temps simply because i really crank the speeds of my rams with liberal voltage use at that (usually dumping volt into freq or trfc) so thatd be where ram cooling is neccesary, and then theres my crappy p6x58de that cant overclock for shit and can only do like 2040 or 1900 ddr3 cause dud board that cant run proper bclk where i can get away with running my 6x4 d9qbj at 2v without a fan simply because of how slow theyre running and loose primaries (9-12-12)
I have the screws, where would you suggest I put the fan I got 2 fans on the front panel as intake and 1 in the back as exaust
I wouldn't.  2 intake and 1 exhaust are perfectly fine, especially with a good CPU Cooler like that.
You have good airflow, going from front to back like a hair dryer.  Cool air in, hot air out.
Same exact setup I have in my Plex server.  2 in, 1 out.
OnePlus Ecosystem:
3D Printing:
Would you remove it entirely?
I'd remove it or get a thinner fan, but most likely not have it.
If you look at how the air moves in the case, this just isn't a natural flow.  If you had 3 fans on top, you could control the flow as a whole.
But 1 fan like that?  Ain't going to do anything.
Might as well hotglue a small 60mm fan to the motherboard on the RAM, if you want to cool them.
Besides, since only you think they're hot (which they are not), it's not even needed at all.
OnePlus Ecosystem:
3D Printing:
Would you recommend using it like an intake if so? Cuz the intake one works perfectly since it’s not touching the heatsink.
You mean have 3 intake?
Take temp check now in some game you can replicate.  Then add it, and rerun the game for temps.
See what provides better cooling.  I think it may help a degree or two possibly.
OnePlus Ecosystem:
3D Printing:
Ye but heard something that it builds up dust easily
What builds up dust?
I am not following.
OnePlus Ecosystem:
3D Printing:
That fan above the ram would do much better as an intake.
Not only will it cool your ram, but it will feed your CPU cooler, instead of robbing it.
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
Are you talking about the fan on the cpu cooler or are you talking about the system fan?
The system fan I guess. The one that is right over the CPU and ram. You have it as exhaust right now, it should be intake.
I’ve tried that in my case. Worse temps on cpu and gpu than having it exhaust. Fighting natural convection.
Natural convection doesnt exist in a computer case.
