Budget (including currency): 75,000inr around 900usd
Country: india
Games, programs or workloads that it will be used for: general programming game development and rendering and video editing
https://pcpartpicker.com/list/kCmXHG
https://linustechtips.com/topic/1528465-new-build-help/
Country: india
I recommend getting a HDD or Sata with that SSD. 1tb is minimum for requirement for what you are gonna do with that PC. Everything else looks good.
https://linustechtips.com/topic/1528465-new-build-help/#findComment-16113891
Ok, Thanks, I have a external 2tb drive it should be good enough
https://linustechtips.com/topic/1528465-new-build-help/#findComment-16115994
Alright, 2+1TB will great work. But, if that ASRock motherboard is not necessary, you can change it to MSI PRO H610M-G. It is 10 bucks cheaper and will give the same performance as the ASRock motherboard. And for a better look for your PC, you can change the case to Deepcool MATREXX 40 3F(https://www.newegg.com/p/N82E16811853101). It is the same price as the Thermaltake Versa H18 and it comes with 3 pre-installed RGB fans that will help you cool down that system. All the other things are solid.
https://linustechtips.com/topic/1528465-new-build-help/#findComment-16118698
