I moved over the summer and my pc started having blue screens really often then last week it actyally wouldnt turn on and itd say something aboutnfixing C drive. Then a couple days ago itnwouldnt even boot and the led would he on. Before i moved everything was working fine for years
5800x
Rtx 3070
X570 a pro
3600 mhz 32 gb cl16 ram
https://linustechtips.com/topic/1527966-cpu-ez-debug-light-on/
Depending on how the PC was transported, it could be something came loose while you were moving. You could try reseating stuff like your gpu, making sure your cpu cooler didn't come loose if you have one that's too heavy. If you have experience in the UEFI/BIOS you could make sure everything is detected there
https://linustechtips.com/topic/1527966-cpu-ez-debug-light-on/#findComment-16108236
5800x
Rtx 3070
X570 a pro
Is it a mechanical drive? Does the system post fine but don't boot, then it is a HDD or windows issue you are dealing with. If you can't post / get into bios, you have a technical issue at hand. Check all your wires and cables. How did you transport the PC, did you properly remove the GPU and cpu cooler while transporting it? Is the RAM seated properly? Is the wall outlet stable or do you share it with other devices like AC, microwave, freezer etc.
https://linustechtips.com/topic/1527966-cpu-ez-debug-light-on/#findComment-16108288
If all of the above don't work try reseating your CPU. Check the socket for damage and check the bottom of the CPU for damage. It could also be a mounting pressure issue
My Rig: CPU : 10700K | RAM : Trident Z Neo 3600Mhz c16 32G (4x8) | CPU cooler : NHD15 | GPU : ASUS ProArt 4070 | PSU : Corsair RM850 (black label) | CASE : Corsair 5000D Airflow | Storage : Samsung 970 evo 1TB, WD Black 1TB, Samsung evo 850 Sata SSD | Casefans : Lian Li Unifan SL120 7X|
MOUSE : G Pro Wireless X superlight | Keyboard : Keychron C1- Pro-H1 Gateron Milky Reds
https://linustechtips.com/topic/1527966-cpu-ez-debug-light-on/#findComment-16108328
