hey can some one help me whit RGB 3pin  connecter
so my case came whit 3 RGB fans built in and i got 3 more case fans from different make
the case fans have LED button  to change colors
wen i connect 3pin connecters  together they dont work if buy an ARGB hub and 5v to 3pin sata
can i connect them all together and use the LED button on case to make same colors
thanks for help
CASE name  IONZ Gamer Edition GE336F
fans  Thermalright TL-C12C
ARGB Controller 5V 3 Pin SATA Power Supply
DeepCool SC700 12-Port ARGB HUB
motherboard msi pro b550m-p gen3 DONT HAVE 3PIN RGB connector
https://linustechtips.com/topic/1526907-rgb-fan-problem/
