Budget (including currency): USD - Cheap, but can run program and has upgrade path
Country: United States
Games, programs or workloads that it will be used for: Golf Simulation FSX Play (system requirements below)
FSX PLAY Software Installation
System Requirements:
(minimum spec)
  • Operating System: 64 Bit Windows 10 or greater
    • not supported: iOS, Linux
  • Processor: 7th Gen or greater Intel i5, i7, and i9 processors
    • not recommended: AMD CPU
  • Memory/RAM: 8GB system memory
  • Video Card: Nvidia GeForce RTX 3060 or greater
    • recommended for Quality/Optimal Performance: GeForce RTX 3070ti/3080/3090
    • not supported: Nvidia Quadro, AMD GPU
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc):  I would like to run this software at 4k on a 120" projector for a home simulator setup.  Space is not an issue and I plan to buy soon.  Would like an upgrade path if possible.
Thanks!
https://linustechtips.com/topic/1526440-pc-build-parts-help/
Rule 0 of asking for a PC build on the internet: dont give a blank check to strangers. State how much do you want to spend that is responsible for your financial state.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1526440-pc-build-parts-help/#findComment-16086942
4 hours ago, billman45 said:
Let’s call the budget $1000 max but I would prefer less but I am not sure what is reasonable.  If $1000 isn’t enough to meet the requirements then what would be that I wouldn’t regret later.
mybe this
(mybe you can go whit used gpu 3060 3070 etc)
https://pcpartpicker.com/list/Tdnxrv
https://pcpartpicker.com/list/jGfQ7R
https://linustechtips.com/topic/1526440-pc-build-parts-help/#findComment-16089147
PCPartPicker Part List
CPU: *Intel Core i5-12400F 2.5 GHz 6-Core Processor  ($149.97 @ Amazon)
CPU Cooler: *Thermalright Assassin X 120 Refined SE 66.17 CFM CPU Cooler  ($18.89 @ Amazon)
Motherboard: *MSI PRO B660M-A WIFI DDR4 Micro ATX LGA1700 Motherboard  ($129.99 @ Newegg)
Memory: *Silicon Power GAMING 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($48.97 @ Amazon)
Storage: *Samsung 970 Evo Plus 2 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($79.98 @ Amazon)
Video Card: *MSI VENTUS 2X BLACK OC GeForce RTX 4060 8 GB Video Card  ($299.00 @ Newegg)
Case: *Fractal Design Pop Air ATX Mid Tower Case  ($79.99 @ B&H)
Power Supply: *Corsair RM750e (2023) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($99.99 @ Best Buy)
Total: $906.78
Generated by PCPartPicker 2023-08-16 11:38 EDT-0400
https://linustechtips.com/topic/1526440-pc-build-parts-help/#findComment-16089361
