12 minutes ago, Zer0foxo said:
Pc turned off won't turn back on made a pop sound when I tried to turn back on is this the power supply or could it be something else i need help
It is most likely a capacitor on the power supply blowing.
Did you see any smoke after it made the sound?
https://linustechtips.com/topic/1525064-help/#findComment-16070634
