Hey,
I am having an input lag issue on my PC. It's a dual purpose work/play build, and in summary the keyboard and mouse *feel* laggy. For about six months now.
What I mean is that the input isn't registered right away and it seems to keep 'inputting' for the tiniest amount of time after it should stop. This is especially noticeable in games where it feels like I am consistently overshooting (i.e., crosshairs usually going a tiny bit past someones head, or walking a tiny bit far and falling off a ledge).
I *don't* notice this on my MacBook Pro when using the same monitor, keyboard, and mouse (admittedly I'm not gaming). I jumped on my daughters PC and played some Valorant, and also didn't notice the issue at all (she has an AMD 5600X with AORUS B550 motherboard and Radeon 6600XT)
The build is:
- AMD Ryzen 5800X w/Noctua D15
- Gigabyte B550 VISION D-P (F15 BIOS)
- 2 x F4-3200C14D-16GFX
- ASUS ROG Strix 4080 OC
- AORUS Gen4 7000s SSD
- Keychron Q3 Pro w/knob (wired)
- Logitech G70
- AORUS FI27Q-P + DP
- ASUS ROG Loki 1000W Platinum PSU
- Windows 11 Pro w/secure boot + bitlocker (AMD TPM) + latest AMD drivers + latest nVIDIA drivers + Logitech G-Hub + one game while I test --you'll be appalled to know it's Valorant 😉
- Mouse acceleration disabled (I use a utility called LinearMouse to do this on my Mac)
- VSYNC is definitely off everywhere, and the monitor is reporting FPS is maxed out (165Hz).
What I have tried:
1. Pulling the build apart and reseating everything after cleaning it with isopropyl (I haven't seen any temperature issues at any time).
2. A different cable, including connecting directly to a USB-C port (there are two) and also using the supplied USB-C to USB-A adapter, and a different (gaming) keyboard).
3. A different mouse (wired gaming mouse).
4. Different USB ports, including the 'keyboard and mouse' ports indicated on the motherboard.
5. A different monitor (including trying HDMI instead of DP, and a different DP cable).
6. Formatting the drive and reinstalling the latest Windows 11 Pro.
7. Not installing anything except windows drivers (no Logitech G-hub) and only one game at a time (I tried Valorant, Cyberpunk 2077, and Control).
8. Resetting and reflashing the BIOS using the Q-Flash button (so like a hard flash).
9. Resetting and refreshing the BIOS and not changing any BIOS settings (I only turn on XMP, PBO, and set fan curves at any rate).
10. A few different BIOS versions including beta versions.
11. Disabling secure boot, resetting the TPM, not enabling bitlocker.
12. Turning off game mode, repairing files with SFC, optimising the drive, doing a file cleanup, I mean I'm getting into the weeds here).
13. Different combinations of the above, reinstalling Windows in between.
What I haven't tried:
1. Replacing the cpu, motherboard, gpu, ssd, or power supply.
2. Windows 11 Home (surely not?)
3. Windows 10
4. Probably lots of other things you'll tell me about!
I've been building computers for 20+ years, so I *hope* I've tested the basics, but I'm very prepared to have overlooked something! I'm honestly wondering if there is an issue with the USB controller on the motherboard. Does anyone have insight for how to test that?
TIA!
https://linustechtips.com/topic/1524955-input-lag-issue-on-pc/
1 hour ago, SiliconT said:
Hey,
The build is:
- Logitech G70
What I have tried:
3. Windows 10
TIA!
There's a BIOS update available:
https://www.gigabyte.com/Motherboard/B550-VISION-D-P-rev-1x/support#support-dl-bios
And there's a vBios too
https://rog.asus.com/graphics-cards/graphics-cards/rog-strix/rog-strix-rtx4080-o16g-gaming-model/helpdesk_bios/
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1524955-input-lag-issue-on-pc/#findComment-16070023
On 8/9/2023 at 5:04 PM, 191x7 said:
The BIOS versions 16b and 16d are beta BIOS, but I did try 16d without any change. I also did try reflashing the V1 VBIOS (the card already had it but I thought it wouldn't hurt...)
Thanks heaps!
https://linustechtips.com/topic/1524955-input-lag-issue-on-pc/#findComment-16073099
  • 3 weeks later...
  • 1 month later...
