I currently have a pc with a 2070 a ryzen 3 3200g and 16gb, i play roblox, minecraft and heavily modded minecraft and recently ordered 64 aka 2x32gb 3200mzh patriot viper steel ram.If it matters still has not arrived, and i have my cpu bottle necking my gpu to only 58% gpu usage would the ryzen 7 5700x be good for me? Im on a budget build btw.
https://linustechtips.com/topic/1524208-help/
2 minutes ago, ChristopherPeach said:
The 5700x would be more then enough as it is an 8 core cpu which will be good with multi-threading tasks. The RAM would not affect your performance as roblox and minecraft are not RAM intensive.
I have the ram for my intense minecraft mods and they use quite a bit
https://linustechtips.com/topic/1524208-help/#findComment-16065253
13 hours ago, BFCGK said:
minecraft is a split game
Man i bloody wish
It is a very CPU bounded title especially if you cut thru the world faster, forcing a bunch of chunk loading.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1524208-help/#findComment-16065909
