Hi guys!
Recentrly I bought an extra R9 280x and set up a Crossfire. Everithing is detected, but whenever I fire up Battlefield 4, I'm getting massive frame drops after 5 minutes of gameplay. When I disable Crossfire, everything works ok.
Checked the card tempratures, and they are around 60-70 degrees when full load.
My specs:
Core I5 2500k
Gigabyte Mother board GA-H67M-UD2H-B3
PSU Cooler Master 750w Silent Pro
12 Gb DDR 3 Ram.
Any help would be appreciated!
Knowledge don't take space. Don't know something? Just ask nicely!
https://linustechtips.com/topic/152396-crossfire-frame-drop/
are both cards under load when you have crossfire on?
System CPU : Ryzen 9 5950 doing whatever PBO lets it. Motherboard : Asus B550 Wifi II RAM 80GB 3600 CL 18 2x 32GB 2x 8GB GPUs Vega 56 & Tesla M40 Corsair 4000D Storage: many and varied small (512GB-1TB) SSD + 5TB WD Green PSU 1000W EVGA GOLD
You can trust me, I'm from the Internet.
https://linustechtips.com/topic/152396-crossfire-frame-drop/#findComment-2035620
What errors are you getting for afterburner (they might be the same things causing crossfire issues)
https://linustechtips.com/topic/152396-crossfire-frame-drop/#findComment-2035690
I've managed to get MSI afterburner to show on screen statistics. Maybe the problem it's something on my CPU. When I disable Crossfire, and use only one GPU, CPU usage is aroud 80/90%... but if I enable Crossfire, then it's 95/100% and I get the poor FPS....
https://linustechtips.com/topic/152396-crossfire-frame-drop/#findComment-2039674
you have to manualy disable ULPS from the registry. im at work so i cant point you to a guide rigjt now, but check online its pretty easy to do, and it will fix your problem.
also download gpu-z if the second card says bus width (cant remember if it appeared exactly like that) to anithyng but 384, then its deffinitely the Ultra Low Power State not properly re activating your second gpu creating a bottleneck, i have the same crossfire set-up so i know xD.
Main rig. Updated :D CPU: FX8350 @stock Cooler: Corsair h110 Motherboard: Ga-990fxa-ud5 Memory: Corsair Vengance 8Gigs 1866Mhz GPU: MSI GTX 970 SLI (blower cooler)  PSU: Cooler Master Silent pro 850w SSD: Corsair Force GT 60Gb HDD: WD 500 Caviar blue Case: Thermaltake core V71 Fan controler: NZXT Sentry
Secondary PC: CPU: i5 4670k @stock Cooler: Thermaltake NIC L/31 Motherboard: Asus Z97I-PLUS Memory: Corsair Vengance 8Gigs 2133Mhz GPU: ZOTAC GTX 780 (Titan cooler) PSU: Antec 520m Pro SSD: Corsair Force GT 60Gb HDD: WD 500 Caviar blue & WD 2TB Green Case: Thermaltake core V1
https://linustechtips.com/topic/152396-crossfire-frame-drop/#findComment-2040460
Thanks. Will try that and report back! You have same crossfire setup and also a core I5 2500k?
https://linustechtips.com/topic/152396-crossfire-frame-drop/#findComment-2041447
I know...quoting a quote...ugghhh...SkuID is right...disable ULPS.  Every update for drivers will enable it again, so do it again when you update.
http://www.tomshardware.com/faq/id-1904869/disable-ulps-amd-crossfire-setups.html
Case: Silverstone SG09B Motherboard: MSI Z10 Morter M-ATX CPU: I5-6600K  Ram: Corsair LP 2400 DD4 16GB GPU: MSI RX 480 Storage: Seagate HDD Baracuda 2TB x2, Crucial M200 500GB SSD X2 (Raid 0)PSU: Silverstone Strider Gold 1000W w/PP05E Kit
"When to say :blink: WTF :blink: ....$2K rig only used for Minesweeper and Internet Checkers marathons...."
https://linustechtips.com/topic/152396-crossfire-frame-drop/#findComment-2041450
Just disabled it. Will report back! Thanks guys!! :D
It will cause your second card to come to life and stay that way.....maybe a couple of cents more for the power company, but should eliminate that as a potential issue with crossfire.  Don't forget about GPU-Z.....my R9 270xs were acting up as well with it enabled...disabled..and BF4 plays great.....hope it helps you out..
https://linustechtips.com/topic/152396-crossfire-frame-drop/#findComment-2041521
Thanks a lot!! Will report back. Quick question, mi core i5 2500k should handle the r9 280x crossfire right? No bottelecking?
Should not bottleneck...although no experience with the 2500k....best of luck and happy gaming ;)
https://linustechtips.com/topic/152396-crossfire-frame-drop/#findComment-2041695
I have a FX8350 @stock speeds, with 2 R9 280x, bf4 plays really nice.
I hope that you are gaming right now xD, if the problem persists let us know.
https://linustechtips.com/topic/152396-crossfire-frame-drop/#findComment-2042091
Thanks so much!! Couldn't try yet, but will update once I test it! What resolution you play? 1080p? Ultra settings? AA? Thanks again!
everything on ultra (maxed everything), motion blur off my screen is a 2560x1080 ultra wide screen from asus.
cant remember avg fps but is over the 60fps
https://linustechtips.com/topic/152396-crossfire-frame-drop/#findComment-2042568
Ok, reporting back.... I got mixed results... Disabled ULPS but I'm still not getting good FPS... MSI afterburner says my cores are at 90/100% almost all the time, and the Gpus usually arround 60-70%... sometimes gpus spike at 80/90% but usually they're around 50-70%... CPU Should not be bottlenecking.... Playing on high, no AA I am around 50-70 FPS... that can't be good for this setup. I play at 2560x1400 resolution.
https://linustechtips.com/topic/152396-crossfire-frame-drop/#findComment-2044930
if cpu cores are hitting 100% while gpus are at 70% then i'd say that the cpu is holding you back.
in my case my 8 cores are around 70% load and so are my gpus (i had v-sync on when i did those tests)
https://linustechtips.com/topic/152396-crossfire-frame-drop/#findComment-2045901
If the issue is only with BF4 try running with DX11.
https://linustechtips.com/topic/152396-crossfire-frame-drop/#findComment-2045965
I am suspecting the same thing....
Isn´t DirectX 11 teh default one? Do I change it in-game?
https://linustechtips.com/topic/152396-crossfire-frame-drop/#findComment-2046241
Yes...change on settings menu between X11 and Mantle.....Mantle crashed on me the other day while gaming, went to X11 and no issues....they will hash these Mantle issues out next update (hopefully)...
https://linustechtips.com/topic/152396-crossfire-frame-drop/#findComment-2046300
Actually Mantle gives me a little boost in performance... But still cpu is peaking 95% - 100%.... :( Thought it wouldn't bottleneck... Just reinstalled Windows and still the same thing.
https://linustechtips.com/topic/152396-crossfire-frame-drop/#findComment-2046588
Wow....not for nothing, try posting over at the CPU forum on this site.....some bright individual may be able to assist if they believe its cpu related.   If you are not overclocking your 2500k, and have the cooling/psu capacity for it...might want to try that as well.  I have linked an article from Toms below about your cpu....also Linus has really good guides on Youtube about overclocking.....good luck and hope you get it sorted out.....
http://www.tomshardware.com/forum/265056-29-2600k-2500k-overclocking-guide
https://linustechtips.com/topic/152396-crossfire-frame-drop/#findComment-2046716
can you OC your cpu? if performance increase then its your cpu the problem.
by the way your main issue is random fps drops right? or do they follow a pattern of some sorts.
also increase virtual memory see if that helps, at first i couldnt even play bf4 because i had virtual memory off.
https://linustechtips.com/topic/152396-crossfire-frame-drop/#findComment-2046726
Thanks again guys! But it's definitively bottleneck what I have. Just tested with MSI afterburner and with only one GPU activated, CPU peaked at 75% usage. And GPU was at 99% almost all the time. Then, I activated crossfire and boom. Cpu usage went to the roof. 95-100% all the time and the GPUS were around 60-70%.
I think I cannot overclock the processor more because of a motherboard limitation. Now I have it at 3.30 mhz, but my Gigabyte Motherboard model (gigabyte ga-h67m-ud2h-b3) has a limited multiplier I'm afraid.
https://linustechtips.com/topic/152396-crossfire-frame-drop/#findComment-2046769
