Need Suggestion for PC upgrade and a few question
11 minutes ago, ChusanaR. said:So I should save up my Ram budget for future better CPU&RAM correct?
Better CPU > better RAM, but yes. If you had to choose though, upgrading to an R5 5600 or 5800x3D would be better. The only limitation you may run into is simply with a B450 motherboard, since it doesn't support PCIe 4.0. If you were to replace your RTX 2060S at some point with an equivalent tier newer GPU, those newer GPUs only have 8x lanes, which can be a limitation if they're not running the full PCIe 4.0 bandwidth they're designed for (although its not that much, maybe 10% performance loss).
If you are willing to skip on the RAM and save for a better upgrade, I'd recommend either the 5800x3D specifically or buying a new CPU+motherboard instead when you've saved enough. Otherwise, I'd skip on investing any more money than that into AM4 at this point. You'll see considerably better performance relative to cost in a 5800x3D upgrade, even with a 2666MHz kit, than an R5 3600 with even the best RAM it can support.
